KAD Anti Roll Bars
AdrianKAD
Re: KAD Anti Roll Bars
Post by AdrianKAD »
Pete wrote:
AdrianKAD wrote:
Pete wrote: So Adrian can customers (ahem..) :D send their mistakenly purchased bars back if they've already been fitted like mine ? (now removed obviously) .
Yes you can. There will be a handling charge to cover replating if we can't sell it 'as new' but otherwise we are happy to exchange them for the shorter bar!
Thanks for that, on it's way !
Magic. We have a batch of 'historic' bars off at plating, due back next Tuesday, so I will get the replacement on its way as soon as they are back with us.
Pete
Has thanked: 56 times
Been thanked: 143 times
Post by Pete »
Still not sent my bar off, should happen tomorrow.
Here's the one on Swifty's new racer from the weekend......
Looks even shorter and modded.
monkeyjim
Post by monkeyjim »
The blades are bent .
My kad ones are straight.
sandman
Post by sandman »
Bending the blades is good.... gives more clearing to the tyre + more importantly; the rosejoint wont schafe against the side of the blade (as it does when at an angle - this makes a very "squeeky" sound)
Looks like they've made their own drop-links too...
Got any more detail photos of Nick's new wonder? :)
Cheers,
Ed_
Pete
Post by Pete »
I think that's an even shorter bar than the historic one , hence the bent blades as you say for extra clearance. Beautifully built car, even the body has panel gaps to die for !
Poor photo this (was in a rush) , note standard pedals (I'm not the only one without fancy extensions then !).
AdrianKAD
Post by AdrianKAD »
We supplied that as two collars and a length of bar!
Its not unusual for people to bend the blades though- that gives more room for clearance and gives you more of a chance at getting the drop links as straight as possible if your set-up is a little different than the considered 'standard' that the bar was designed for. Swifty has access to a press though, so bending the blades evenly and nicely is easily done. Its not so easy at home in a bench vice with a hammer and scaffold bar as your only metal forming tools!
lexie467
Post by lexie467 »
Instead of bending use a spacer otherwise the ball can not fuction fully in the rose joint!
Tommy
AdrianKAD
Post by AdrianKAD »
lexie467 wrote:Instead of bending use a spacer otherwise the ball can not fuction fully in the rose joint!
Tommy
Well spotted- I hadn't noticed that, the rose joint is butted straight up against the blade which is incorrect.
I'll remember that next time they come on. ;)
