Avon tyre pressure
Sugy77
Avon tyre pressure
Post by Sugy77 »
Hello together,
Last week a fitted a set of Avon tyres. First impression is very positive. What would be the correct tyre pressure for these? Avon on Rose Petals for fast road application?
Many thanks in advance
Fabio
GraemeC
Been thanked: 7 times
Re: Avon tyre pressure
Post by GraemeC »
I run at 28psi
LuisM
Post by LuisM »
I run at 28psi
Same pressure for me !
Pls note Avon’s require some warming up , avoid pushing then when cold !
Luís
Sugy77
Post by Sugy77 »
Hello,
Thanks a lot.
Same pressure front and rear? In generale 29psi sounds like a lot to me. The tire appears to be rather rigid in its structure so I was assuming a lower pressure to be adaquate.
Thanks and regards
Fabio
GraemeC
Post by GraemeC »
Same front and rear.
28psi works well, both wet and dry. You won’t gain any more grip running lower pressures, just get them hotter and scrub them more.
IanD1965
Post by IanD1965 »
Assuming you are talking CR6ZZ tyres.
I used these as wets for hill climbing. I used to run 16 front and 14 rear. Very good wet or dry.
gazwad
Post by gazwad »
How do these tyres compare to the yokohama a032’s in terms of traction from standing starts, cornering grip and wear rate?
GraemeC
Post by GraemeC »
Possibly lose out slightly on a standing start, especially if cold, but otherwise better. Just much more expensive.
gazwad
Post by gazwad »
Thanks, I have found I am wearing the outer edges of the yokos very quickly on the track due to the soft sidewalls allow the tyre to tuck under, I’m going to try more negative camber to counter this but I expect the stiffer sidewalls of the avons would be a better solution, it’s just a shame they are more than twice the price!
wantafaster1
Has thanked: 16 times
Been thanked: 11 times
Post by wantafaster1 »
Yes more expensive but last longer.
My mate did the manx rally and went to Killarney on the same tyres.
Two front yokos last about 25 miles.
LuisM
Post by LuisM »
i can get at least double the usage of Avon's against A032's.. this on abrasive tarmac ( Track day usage ).
Grip when hot is better but the major difference i noticed is less understeer with Avon's ( and that was with 5x10 wheels , against 6x10 with A032 )
they are a very heavy tyre though.
