Twin H4 choke lever
A1111j
Twin H4 choke lever
Post by A1111j »
Hi guys I just picked up a set of H4s and the the chike lever parts numbers are AUC4045 is this correct?
Herbert
Re: Twin H4 choke lever
Post by Herbert »
Is this the one you are looking for ?
http://sucarb.co.uk/levers-throttle-sto ... 30079.html
A1111j
Post by A1111j »
I have read somewhere that those choke linkages are cooper work linkages?
Desmodromic
Post by Desmodromic »
A1111j wrote: Sun Feb 13, 2022 2:06 am Hi guys I just picked up a set of H4s and the the chike lever parts numbers are AUC4045 is this correct?
Yes, I have those choke levers on my H4s (and also on pairs of H2s and a pair of H1s on my Frogeye Sprite)
A1111j
Post by A1111j »
Great so I don't need to change them to the other number? What manifold is everyone using I was thinking for getting the maniflow L149.
Desmodromic
A1111j wrote: Sun Feb 13, 2022 3:09 pm Great so I don't need to change them to the other number? What manifold is everyone using I was thinking for getting the maniflow L149.
Yes I use Maniflow manifolds with my H4s. If you phone Maniflow to place your order you can ask them to modify the carb facing flange if you want. They will also ask you for the size of the intake ports on your head.
The standard L149 carb flange is designed for both H4 and HS4 mountings. I got them to simply use H4 pattern flanges on mine.
I did have a nice period aftermarket cast alloy one, which worked well, but sold it ages ago. I pretty much only use Maniflow manifolds these days except where originality is required.
A1111j
Post by A1111j »
Great thanks for that. Isi possible for you to post a photo of your setup? I think my carbs might be missing something. Thanks
Desmodromic
These should help: https://mk1-performance-conversions.co. ... itting.pdf and https://mk1-performance-conversions.co.uk/h4_parts.pdf
It's worth noting that some of these fittings - choke bracket arch etc. are standard on Frogeye Sprites so easy to obtain from the relevant suppliers.
