Water pumps
colonel mustard
Water pumps
Post by colonel mustard »
Hi all,
I have pulled the engine out today and discovered the newly installed water pump earlier this year is leaking, quite badly.
Looking at either the mini spares or MED units, apart from the cost what is the actual difference, if any between these items?
http://minispares.com/product/Classic/C ... o%20search
https://www.med-engineering.co.uk/water-pump-925
Thanks in advance
Has thanked: 38 times
Been thanked: 37 times
Re: Water pumps
If I was you Colonel, I'd be looking at a rebuilt original cast unit. I put one, rebuilt by a member here ages ago and it's given perfect service ever since. All original but with new bearings and seals.
minibitz
Re: Water pumps
Post by minibitz »
The both took like the same pump to me.
Swiftune version appears to be an MS pump with £15 markup on it.
I've been using the MS EVo pumps since they were introduced and have yet to replace one or had any other issues with them.
I always check the impeller is pressed fully into position and also that all the internal flashings from the casting have been removed.
Have had lesser quality pumps with impellors either catching or too far away from pump body and also had flashing left inside pump body completely blocking inlet from bottom hose.
AndyPen
Has thanked: 7 times
Been thanked: 34 times
Re: Water pumps
Post by AndyPen »
minibitz wrote: Sun Dec 19, 2021 11:34 pm The both took like the same pump to me.
Yes definitely check, I had an Evo one cause me all kinds of issues and head scratching. When I finally removed it, the casting was still there - with the result that no water flowed at all. I had the same problem with my genuine Ford RS500 one, but was able to drill that out in the engine bay with the rad removed. Maybe not that rare, or maybe I am just unlucky?
OzOAP
Re: Water pumps
Post by OzOAP »
minibitz wrote: Sun Dec 19, 2021 11:34 pm I've been using the MS EVo pumps since they were introduced and have yet to replace one or had any other issues with them.
Same here. Just give them a check over, like you should do with everything nowdays. Never had any issues.
Desmodromic
Re: Water pumps
Post by Desmodromic »
Another vote for the MS Evo pump from me, works well, and has not leaked since fitting. As others have said, definitely inspect carefully before fitting
Andrew1967
Re: Water pumps
Post by Andrew1967 »
Peter Laidler wrote: Sun Dec 19, 2021 9:51 pm If I was you Colonel, I'd be looking at a rebuilt original cast unit. I put one, rebuilt by a member here ages ago and it's given perfect service ever since. All original but with new bearings and seals.
Agree with Peter, get an old cast iron one rebuilt like I have for myself and a few on here .
AndyPen
Re: Water pumps
Post by AndyPen »
Andrew1967 wrote: Mon Dec 20, 2021 1:20 pm
That is what I am doing - thanks to Andrew ;-)
Re: Water pumps
Maybe Mechanical Maestro Andy ought to do a 'how to fix it' article......., when he's finished is book about restoring HOY!
Andrew1967
Re: Water pumps
It's easy Peter.
Remove from engine, put it in a box and send up to Paul King (not he of the 80's band King) at E P Services.
Once returned, usually within three days, paint and re-fit ;)
cmiller
Re: Water pumps
Post by cmiller »
Not to hijack this thread but the website for E P is not functional. At least here in the States. I remember they used to sell the kit or parts for us do-it-yourselfers. Looking for a current contact address.
Chris Miller
Andrew1967
Re: Water pumps
Their site is under construction still .
I’ll dig out Pauls contact details
Andrew1967
Re: Water pumps
Alex
Re: Water pumps
Post by Alex »
As should be the case with all fixings, make sure you torque the EVO pumps correctly and don't go full-gorilla and do them up FT.
The rounded profile sealing face can pinch-cut through a gasket if it's done up too tight.
colonel mustard
Re: Water pumps
Thanks All,
Have sorted a new EVO pump along its gaskets and new bolts, potentially looking at up using some gasket sealer, any thoughts / recommendations?
Also to add I have an op.Timon of using the paper gasket that comes with the EVO unit or I have one of these:
https://www.med-engineering.co.uk/med-water-pump-gasket
iain1967s
Re: Water pumps
Post by iain1967s »
colonel mustard wrote: Thu Dec 23, 2021 8:03 pm potentially looking at up using some gasket sealer, any thoughts / recommendations?
I use a thin smear of Permatex aviation form-a-gasket #3 on both sides of all paper gaskets, never had a leak.
360gts
Been thanked: 27 times
Re: Water pumps
Post by 360gts »
cmiller wrote: Tue Dec 21, 2021 3:39 am Not to hijack this thread but the website for E P is not functional. At least here in the States. I remember they used to sell the kit or parts for us do-it-yourselfers. Looking for a current contact address.
Chris Miller
Happy Christmas Chris,
There a re few companies in the US that supply these parts. I bought some from a Massy Ferguson parts supplier. Old Massey tractors used the same water pumps. Sorry I don't have the links now.
65MK1S
Re: Water pumps
Post by 65MK1S »
Anybody know what the correct clearance of the
impellers should be? The new pump I got from MS
seems to be quite wide at about .024 thou and the
cast iron pump I have is at about .010 clearance or
does it really made a difference other than at low rpm?
colonel mustard
Re: Water pumps
Thanks Ian,
Just ordered some.
indigo
Re: Water pumps
Post by indigo »
In the process of fitting a new Minispares EVO pump and want to check the impeller clearance, casting flashings, etc.
Should the impeller clearance be 10 thou as per the original cast iron pumps? It definitely looks more than this.
