EcoClassic Electric Mk1 Austin Mini
- Bitsilly
Re: EcoClassic Electric Mk1 Austin Mini
I’m flattered, thanks so much!
I have just had a few issues on getting the wipers to work properly and park on the correct side, now that I have changed them to two speed and park. Nothing to do with electrifying a mini so I have posted the information in the Technical threads.
Currently still waiting for the rear battery pack but unfortunately Nick's family have caught Covid so there is a slight delay.
- Bitsilly
Ok, well the battery for the boot has been assembled by Nick based on the space allowed according to his 3D scan done some time ago:
And the finished battery shown from the back.
He sent a couple of photos of the assembly in progress too, note the Miglia in the background!And the finished battery shown from the back.
- Bitsilly
To save time and to be ready when he drops over the battery next week, Nick has sent me a copy of the base plate that the battery is built on so I could fit the flat solid base needed for it to sit on.
The datum to work from is the back LHS of the boot and then to fit brackets for the other corners for the battery to bolt to.
The other side:
And final check! Phew!
The other side:
hi mate
where do you put the spare wheel or are you going to run run flat tyres or carry them on the roof on a rack
cheers roger mcnab
cheers roger mcnab
Incredible work.
This thread & the Doc's are both extraordinary!
- Bitsilly
Cheers again, but Doc's car is another universe altogether!
This is the current plan for flat tyres!
However I do have a roof rack now for longer trips.
The new rims came with tyres but I honestly hadn't thought of run-flats! I will have to check them out, makes a lot of sense for my next set!
- Bitsilly
Well the good news is that the boot battery pack was delivered and immediately fitted on Saturday.
Yet again I am impressed by this 3D scan lark which Nick used to size the battery pack, it slotted in really well although I insisted on a few measures to protect my paint! It was also a heavy bugger so yet again my ancient engine crane and some paracord came in useful!
- Bitsilly
Once in place, and remembering the 'old side' loom 12V battery has to fit in the boot as well, there is not copious quantities of boot space left for holiday luggage if your back seat is required for people!
These batteries are light weight lithium ion, how on earth lead acid cars ever moved I cannot fathom!
- Bitsilly
Now that all the heavy hardware is in place, I can finally move on to building the loom and so getting the car moving!
Bearing in mind that every stage in this project has been delayed by Suez canal blockages, Covid viruses, absence of truck drivers etc... I fully expect a rogue satellite to fall out of orbit and bop me on the head!
But let us stay positive!!
Nick provided me with these: He will work on a simpler schematic lay-out for future projects, but in the meantime I have to build the loom for my car!
- Bitsilly
I gave him a 'slightly' bad time over his nomenclature, basically because I couldn’t understand it! But to be fair it is my job to build the loom to keep my costs down.
First step was translating all the acronyms, of which I counted 17!!
- Bitsilly
All I have to do now is find a blank wall large enough to pin out this loom! And to be fair it really is quite straightforward once I figure out the geography of everything. Straightforward but not exactly simple!
- Bitsilly
One more thing.
The battery packs I have allow about 130 mile range.
I mentioned before that fewer batteries meant less range but also less performance.
It seems now that I was wrong. Less batteries does mean less range but not less performance following a development that Nick recently made to his control systems.
The next fewer number of batteries (I think it has to be a multiple of 8) would free up a lot of boot space, reduce weight but reduce range to around 80 miles. That range would have been fine with me as it will be a commuting car.
So I could have saved money and weight by not jumping the gun!
Bother!
Bother!
hi
i hope that there are lots of recharge points in the area
cheers roger
cheers roger
Another great update!
Things are really moving on now.
I look forward to the next.
- Cole Liggett
Really enjoying this build! I’ve been thinking about converting my Vespa, nice to get some ideas from your build.
1963 Morris Mini Cooper 997 - 4461 KX
hi
well a battery powered vespa will be a challenge but good luck cheers roger
- Been thanked: 3 times
Depending wich model you have, there are allready Kits on the market:Cole Liggett wrote: ↑Tue Nov 09, 2021 3:44 am Really enjoying this build! I’ve been thinking about converting my Vespa, nice to get some ideas from your build.
https://www.sip-scootershop.com/de/prod ... ktro%20kit
- Bitsilly
It has been a while since my last post, basically because I had covid. Vaccinated so only as a bad cold but enough to keep me from the garage.
So armed with a heater I have finally made a start on doing some wiring having and prevaricated as much as is humanly possible!
Three days and I have this to show for it. It is basically the wiring for the OBC or the on board charger if you are a bit slow like me!
Still it is a start!
- Bitsilly
I forgot to say,
Nick actually reckons the range of the car will be more like 200 if driven wisely, and around 160 if not.
So that’s a range of 160 then!!
- MiNiKiN
- Has thanked: 18 times
- Been thanked: 9 times
If you have a smallframe Vespa this Kit is the dogs gonads:Cole Liggett wrote: ↑Tue Nov 09, 2021 3:44 am Really enjoying this build! I’ve been thinking about converting my Vespa, nice to get some ideas from your build.
https://crank-e.at.host24.profi-server. ... kit-speed/
You need to put it through Google translate, as it is German
