I am running my fuel and brake lines inside my car, so need to make up them up to fit.
But one stupid question.
What size brake a fuel line do I use.
And we're is the best place to get the pipe and unions from.
Thanks dean
Fuel and brake lines
- Andrew1967
Re: Fuel and brake lines
5/16 for fuel but I thought brake pipe was normally 3/16.
Pipe and unions from your local trade motor factors will probably be cheapest.
- pad4
easiest way to sus this - what size is the pipe on your fuel pump, and just use std mini size brake pipe
The fuel line, in steel tube, should be 1/4" and the brake, also in steel bundy should be 3/16". Although many do use 5/16 flexible fuel pipes, you should never use brake pipes larger than 3/16"
- Pete
- Has thanked: 39 times
- Been thanked: 105 times
If you can afford it use sweatless fuel hose and make sure the unions are not inside the car. Even a dry looking joint, especially one with a jubilee clip can stink of petrol.
