Carb question 1000cc
Been thanked: 10 times
:roll: What would be better on a 1000cc,
an hif 38 or an hif 44 ?
Kees.
InnoCooperExport
Has thanked: 4 times
Been thanked: 9 times
Re: Carb question 1000cc
Post by InnoCooperExport »
As my mother would say "not hindered by any knowledge" I would say the 38 would be more suitable. The 44 being the carb of choice for 1300s and bigger, and a 38 is basically as big as an HS4 I should imagine that should be fine. Maybe it also depends on the head you're using.
CooperTune
Post by CooperTune »
I have been doing hot rod 998s for awhile. Big bores, .060 /080 and larger. Flat top press fit pistons and rods. 295 cyl heads with O/S intake and exhaust valves and surfaced for compression. Camshaft to suit the customer. While I have not tried a HIf 44 I have used the HIf 38 on all of them with good results. Steve (CTR)
CooperTune
And while you did not ask I'm running a pair of MGB HIF 38s on a 1400 cc 1275 GT unit. The reverse linkage is fun. Steve (CTR)
;) Thanks guys.
