Some of the cars on here look really impressive show winning cars and so I wondered what you guys use top stop your nuts from going rusty..... An example os the nuts and bolts etc on the front ball joints. Having done several thousand miles mine look distinctly rusty and short of washing and drying them off every time I use the car I wondered what finish other people on the forum use to keep their nuts looking good
Stainless, plating, paint...? Cheers. Mark
Good question. I have the Same problem here with quickly rusting ball joints etc.
I intended using a clear spray laquer on the offending nuts etc when I start putting the Woody back together.
Any other suggestions as to how you learned folk would tackle the issue..?
Great. Which bits can be plated? What plating did you use? I was unsure with this as I thought it may interfere with shimming etc. Are you pleased with the results? Are you able to use the car without fear...
Cheers. Mark
Same as dean , ive used all stainless. works out quite expensive though
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
