Discs - today's discovery - do I paint anything?
AndyPen
Has thanked: 18 times
Been thanked: 50 times
Post by AndyPen »
Well one more little treasure that has turned up is a pair of these S Discs dated 1990. Do I recall the hub bit being painted on the originals? Or were they bare metal? I think the hubs themselves were bare metal weren't they???
The rust is so surface that it comes away with ease, a little job for tomorrow ;-)
So do I paint anything folks?
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Re: Discs - today's discovery - do I paint anything?
Post by Polarsilver »
I paint the not important surfaces .. does it matter what OE was ? :o
MiNiKiN
Has thanked: 86 times
Been thanked: 31 times
Post by MiNiKiN »
I blasted and painted everything on my OE discs with aluminium-zinc spray, even the friction surface slightly, to prevent immediate corrosion until restoration is finished.
Rather have non original paint on than original rust.
Andrew1967
Post by Andrew1967 »
I'm planning on using the Frost brake grey on the non friction surfaces to stop the rust on my NOS genuine discs Andy.
I toyed with leaving them 'au naturelle' but decided the inevitable rust would piss me off.
Has thanked: 139 times
Been thanked: 120 times
Me, personally, I'd get rid of the rust the least abrasive way possible and then wipe down in meths . Prime and paint every non friction surface in heat resisting black (I used radiator paint). On the friction surfaces of the disc, spray with SUPERTROL 001. Leave for a day until the supertrol changes from a thin oil to a thick grease. Put in a zip-lock bag and store away. Suoertrol...... If it was good enough to protect vehicles and armour going to 'the Gulf' by sea as deck cargo, it's good enough for my car - and discs I say.
Don't forget that there's no such thing as surface rust. ALL rust, however deep is surface rust
AndyPen
Post by AndyPen »
Paint it will be then. Just been looking at my Aston's brakes and indeed, the actual rotors are bare and that's all.
Thanks for the replies, apart from two spots that needed a wire brush on a drill, wire wool did the trick in seconds. Amazing after all that time!!!
Dr S
Post by Dr S »
I’m utterly flabbergasted by this thread. Why would you paint the discs? The sweep of the pads will keep the rust at bay. Surely the factory never painted them?
Polarsilver
Dr S, "only paint the none friction areas on a Brake Disc & Not any Machined surfaces" ..with the purpose to stop rust ;)
Polarsilver
Anyone remember back in the day when Disc Brakes had just started to appear on everyday type cars .. yes it was Trendy to put an oval shape Sticker on the back of the car that just said "DISCS" 8-)
spoon.450
Post by spoon.450 »
Painting discs..... :shock:
AndyPen
Post by AndyPen »
spoon.450 wrote: Fri Mar 26, 2021 10:21 pm Painting discs..... :shock:
Sounds like a few people have jumped to a conclusion here??? I am doing the same as on my Aston and keeping the rotors (aka the disc part) clean and painting the rest with heat paint.
As Peter suggests, whilst waiting to be fitted I can then protect them, to clean off before fitting.
spoon.450
Post by spoon.450 »
Ahhhh....
AndyPen
Post by AndyPen »
spoon.450 wrote: Sat Mar 27, 2021 9:04 amAhhhh....
Lol ;-)
Using the Aston original heat paint as an inspiration and after a little cleaning and abrasion, I have chosen alloy colour heat paint as so far, it has lasted about 8K miles / 4ish years on the Aston and, er, I have had those rotors glowing ;-)
Andrew1967
Great minds think alike Andy .. here's part of my painting day today ..
Frost brake grey ..
AndyPen
Post by AndyPen »
Andrew1967 wrote: Sat Mar 27, 2021 5:28 pm Great minds think alike Andy .. here's part of my painting day today ..
Frost brake grey ..
Hmmmmm, I think I prefer your colour ;-)
Been thanked: 10 times
So I'm not the only one :lol:
MiNiKiN
Post by MiNiKiN »
"Disc Painters" unite... :!:
:lol:
