Mk 1 door hinge puzzle
- Has thanked: 6 times
- Been thanked: 6 times
Can somebody emlighten me as to which hinge goes where on Mk 1 doors. I have just gone to hang my doors and have no idea which goes where. I think all 4 differ and they appear to have single numbers cast in to them. Any help welcomed. Cheers. Mark
Rolesyboy
- Been thanked: 34 times
Re: Mk 1 door hinge puzzle
This might help.
Marvellous. I had a quick scan of the numbers but it is in a bodyshop away from home and I only had a short amount of time to hang the doors. Thanks Bob.
Rolesyboy
- YMJ
Don't want to sound too patronising but if you take your time and look at the curvature of the hinges compared with the curvature of the doors, you can generally work it out in a few minutes which one goes on top and which side. Certainly if you get one wrong, you can see it straight away
YMJ wrote:Don't want to sound too patronising but if you take your time and look at the curvature of the hinges compared with the curvature of the doors, you can generally work it out in a few minutes which one goes on top and which side. Certainly if you get one wrong, you can see it straight away
i had a set of hinges once that someone had repinned and got the bigs and the smalls mixed up.
now THAT caused some problems
guru_1071 wrote:i had a set of hinges once that someone had repinned and got the bigs and the smalls mixed up. now THAT caused some problemsYMJ wrote:Don't want to sound too patronising but if you take your time and look at the curvature of the hinges compared with the curvature of the doors, you can generally work it out in a few minutes which one goes on top and which side. Certainly if you get one wrong, you can see it straight away![]()
ive just rectified the same
trouble is the hinge is now sadly scrap..the odd angle has worn the metal away
hi thanks for this interesting subject,does this also appear on early brass hinges
On the brass ones, where the big numbers...1,5,7...there are markings:
6818=RHTop
6819=LHTop
6820=RHBottom
6821=LHBottom
6818=RHTop
6819=LHTop
6820=RHBottom
6821=LHBottom
If I've managed to "lose" most, if not all, of the special tapered washers that go on the backside of the hinges, is that going to be a big deal? Can I hang the doors with regular washers on the back of the studs?
Thanks,
Warwick
Thanks,
Warwick
Warwick
Classic Car Adventures
Classic Car Tours & Rallies in Canada
http://www.classiccaradventures.com
You could, but most likely this would cause outward dimples / pulls on the doorskin next to the hinges, not good!
