bus
guru_1071
bus
Post by guru_1071 »
after about eight months of serious heartache, expense, hours and hours on the internet searching for simple bits (no handy specalists who stock all the bits i need............... ;) ) and some serious hours laid over the top the engine i can finally announce that......
{vavaluza blast on}
the bus is running again!
{vavaluza blast off}
its making 28 volts running (better than the pathetic 18 volts the previous 'fully rebuilt' alternator managed), the exhaust doesnt blow, all the water pipes are now perfect, they are all able to be replaced in situ easily - and are all 'off the shelf' items, the gear lever feels like its got a fighting chance of selecting gears, rather than the luck dip method before, the fan belt is correct (and i have a spare), the fan belt adjusts ok, the alternator jackshaft runs parallel, the seat is now bolted to a frame so its easily removable in situ etc etc.
the costs have been horrific - 200 quid on silicon hoses, 50 quid on a 30 year old gasket set just to get one single gasket (which had shrunk and had to be 'grown' back to the correct size) are a few that spring to mind
the difficulty in finding parts is immense - it took six months to find a company who had a set of exhaust gaskets!
none of the 'specalists' (and i use this word very, very tounge in cheek) where unable to read a parts book - they needed the exact model the engine came from (er, i dont know...) or the engine number (which i eventually found on the engine by using a rag soaked in brasso on a two foot long stick and a endoscope camera to be able to get close enough to read the numbers. none of them where able to make the assumption that an engine made for 20 years would have some parts that remained the same........ it drove me round the bend, in the end i just got into the habit of ordering parts in the hope they where right, sometimes it worked, some times it didnt!!!!
the final sticking point was the ring that went between the manifold and the down pipe, i had no idea what size it was or the shape - i bought about 10 various shaped bedforf and leyland ones of ebay (average price a fiver) and none fitted, i then went to the local auto factors and rummaged through his rack - and lo and behold found a bmw that fitted - cost? - £1.60 - bargain!!!
big thanks to mark (for the gear lever bushes) and fishy for the help.
i might actually get some use out of it this summer!!!
minipete
Re: bus
Post by minipete »
Good news then Rich,just need some photo`s now.
littler
Re: bus
Post by littler »
we all moan, but we dont half love it all really ..... character building apparently :roll:
Re: bus
Ting, Ting.
TICKETS PLEASE!
guru_1071
Re: bus
Post by guru_1071 »
heres a picture of the motor, it weighs more than 600kg - note how the rocker box is level with the floor - deep joy - every thing you need to work on is 'just' out of reach!
drivers bit, the seat is the proper 1960s one thats correct for the coach - its actually pretty comfy
guru_1071
Re: bus
Post by guru_1071 »
for the first time this year the bus slipped its berth and we went out for a five mile cruise.
heres a picture of my bro driving it for the very first time
its a lot quiter in the cab no thanks to the work done on the exhaust - you can almost hear other people now!
:geek:
littler
Re: bus
Post by littler »
motors heavyer that my whole MINI,
nice clive tricky race seat you got there rich :D
acespeed72
Re: bus
Post by acespeed72 »
looked great with my minivan in the back :D
towners
Re: bus
Post by towners »
Looking good rich
Have a mate who has a some nice cars and races a old single seater in conversation he mentioned he had a bus
guru_1071
Re: bus
Post by guru_1071 »
isnt that one of the BMC ones???
i was so flushed with the sucess of getting my bus going last week that i decided to get the front springs off so i can get them retempered - it needs doing as they have sagged and it sits on (or nearly on) the bumpstops all the time, so when it needs the suspension to work it just bottoms out on the big rubber bumpstops before the springs and shockers have a chance to work - kind of like what happens to a mini when you fit those stupid oversize hydrolastic comp bumpstops!! ;)
as with everything on the bus its all huge, once its unseized it comes undone with effort - i only had to cut the head off one of the bolts, then use the nut to slowly 'walk' the remaining rusty shaft out of the bush.
the hunt is now on for a VA series shackle bolt, 5" long 3/4" thick with an 1 1/8" head in dash 3 material spec (bedford part number 433504 ;) )
the springs are so heavy its a serious effort to lift even one of them!! :shock:
forgot to take a photo of the springs...
66S
Re: bus
Post by 66S »
Hi Guru,
I could possibly find something here in NZ, let me know if you're stuck.
Regards
Pandora
Re: bus
Post by Pandora »
Rich, do you need a PSV licence to drive it, or is it just on a normal licence if you don't carry passengers>
Mini4Ever
Re: bus
Post by Mini4Ever »
How easy would it be to convert it for carrying Mini's? :roll:
Too many cars...
Pandora
Re: bus
Post by Pandora »
very easy - open the back doors and drive up the ramp!
guru_1071
Re: bus
Post by guru_1071 »
66S wrote:Hi Guru,
Regards
al
many bedfords where exported out to your neck of the woods, so there probably is plenty of spares tucked away!
thanks for your kind offer, but im sorted this time, armed with my parts book i was able to collect this little lot
cost £71 mind you! but turned up next day!
the springs are going to be retempered next week
happy days!
guru_1071
Re: bus
Post by guru_1071 »
Pandora wrote:Rich, do you need a PSV licence to drive it, or is it just on a normal licence if you don't carry passengers>
its registered as a motor home, so no need for psv.
guru_1071
Re: bus
Post by guru_1071 »
Mini4Ever wrote:How easy would it be to convert it for carrying Mini's? :roll:
bart, easy
you just have to get the wheels in line...........GET THE WHEELS IN LINE!!!!!!!!!!!!!!!!!!!!! :lol: :lol: :lol:
:ugeek:
IAIN
Re: bus
Post by IAIN »
:D I like that , another name for a garage. " A MOTOR HOME " :lol:
Etienne B.
Re: bus
Post by Etienne B. »
IAIN wrote::D I like that , another name for a garage. " A MOTOR HOME " :lol:
:lol: :lol: :lol: :lol: :lol: :lol:
66S
Re: bus
Post by 66S »
guru_1071 wrote:al
many bedfords where exported out to your neck of the woods, so there probably is plenty of spares tucked away!happy days!
There were heaps of Bedfords, trucks and buses. They nearly built the bloody county !! There are still parts available, so let me know if you do need something.
Regards
