Cooper S block & main bearing cap markings
Cammsjb
Re: Cooper S block & main bearing cap markings
Post by Cammsjb »
Photos taken to show matching number Y 106 on main bearing cap and block on thick flange 'S' engine.
OzOAP
Post by OzOAP »
Got a 'flat front' block here C1103...think that means it was cast on a Tuesday but machined on a Thursday...
Aginley
Post by Aginley »
What about this one Simon
Robvee
Post by Robvee »
I am new to the forum, hello all, and, hoping to rekindle an old thread.
I have a 1966 (April/May) South African Austin 1275 Cooper S that will be restored soon.
Can anyone confirm whether the main cap numbers were ever stamped on the top face of the engine cylinder block, directly beneath the engine number plate? This would only be visible when the plate is removed. It has been suggested to me that the number stamped on the engine block should correspond to the number on the main bearing housing caps. I have not yet stripped down the engine so I am unable to confirm.
The number is "TP3287".
scooperman
Post by scooperman »
first-type 1275 S block, main cap number 1P 2451 stamped on back of block in the fuel pump casting boss:
second-type 1071 S block, main cap number C939 stamped upside down below the deck above the water pump
