Works Flash / Wipe switch Wipac series 183
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... NA:GB:1123
I have found one of these switches in my box of Mini junk. I have checked it out with an ohm meter and it works fine. The switch is real sloppy, not precise at all. To make the switch you either push the lever up, down, sideways or even in to make the contact. Is this how they are supposed to be. It does not appear worn at all and I suspect it has never been used.
Does anybody have any info on these please?
Daz
Daz
Re: Works Flash / Wipe switch Wipac series 183
Daz
Sounds like a Lucas item
dazibee wrote:No it is a Wipac series 183
Ahh so my little joke, was aemed at the wrong target
I have a couple of Wipac reverse lights, on my car, they work very well.
LUCAS "the prince of darkness" what a brilliant misnomer
on works cars LUCAS flashers were used, not the Wipacs, contrary to what all ebay sellers claim. I will try to find a proper pic. They do look similar to Wipac's, but have a different rear-dash fitting, more like a small barrel, and lucar terminals. They came in 3 different lengths. Now, where is my Abingdon anorak....
ORX7F wrote:on works cars LUCAS flashers were used, not the Wipacs, contrary to what all ebay sellers claim. I will try to find a proper pic. They do look similar to Wipac's, but have a different rear-dash fitting, more like a small barrel, and lucar terminals. They came in 3 different lengths. Now, where is my Abingdon anorak....
That makes sence, with all the works info, as it explains how 2 (or more?) Lucas wiring specialists,
worked almost fulltime, for Abingdon/BMC/Works.
- Been thanked: 7 times
In the '50s and '60s Wipac (from Wico Pacy) components were the cheaper option over Lucas. For example, on the high end models of BSA motorbikes 'quality' Lucas components were used while the low end models used Wipac to save a few bob.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
So the switch being all woolly and wobbly is normal then?
It's going on ebay later to start its new life as the basis of a dodgy Works replica Cooper S for somebody. At least it will make someone happy rather than stored in a box for another 35 years.
These switches do feel strangely wobbly in operation.
M.
M.
That's good to know. Mines in perfect working order then.
I reckon this is the correct switch. cannot believe that a car individually wired by Lucas personel used Wipac parts.
http://www.ebay.co.uk/itm/250947677111? ... 1558.l2649
