1275GT 8 port group 2
tom17
Post by tom17 »
Hi ,
Here is my project for historic racing , a 1275gt group 2 ( period G2 ) with cooper's engine and weslake 8 port cylinder head.
I made a replica based on the works 8 port clubman YMO 886J ( I know it was initialy build for group 6 but can raced in group 2 with minor modifications )
All parts from the engine are original special tuning.
I use a modified round nose mini to build my GT ( a mk5 body that will be converted to mk3 )
The engine rebuild is in progress.
I will share next steps !
JC T ONE
Re: 1275GT 8 port group 2
Post by JC T ONE »
Nice project - and some cool S/T bitz 8-)
roger mcnab
Post by roger mcnab »
that is an unusual head have never seen one like that were many made
cheers roger mcnab
Fanfaniracing
Post by Fanfaniracing »
What a nice Project!
tom17
Post by tom17 »
Thanks,
Today I have received the left and right tank as fitted on rally car.
Normally I can use a third fuel (bag) tank to have a better autonomy like Works rally car , but I will wait to know more about the engine fuel comsuption, maybe 50 liters wil be sufficient to race today ( rallies are more shorter today ).
I have find also original repro of C-AJJ4020 wings extentions for 1275GT groupe 2 as describted on homologation form.
What a GREAT project!
Those bits won't have been easy to source :)
olfrjf
Post by olfrjf »
Superbe Projet, superbes pièces :shock: ;)
tom17
Post by tom17 »
tom17
Post by tom17 »
Gearbox rebuild with all original ST gear set !
tom17
Post by tom17 »
kevs 1961 mk1
Post by kevs 1961 mk1 »
that looks to be an excellent project ,with some rare parts used ,keep us up to date with pictures
long time gone
tom17
Post by tom17 »
Today I have started to pre-assembling the engine , i have bought the engine dismantled as you can see on the first page.
I have checked the block and crank line , pistons clearance ( 0.0035in/0.090 mm , great !), timing and mesurate/control all the parts etc etc to prepare final assembly.
I have a question , I have see that the camshaft have two pinion , one for distributor , but the other one ?
If someone can tell me why ? ( I think it maybe for a pump ... )
roger mcnab
hi mate
the oil pump is usually driven from the end of the camshaft what that other skew gear is for is a mystery
cheers roger mcnab
tom17
Post by tom17 »
roger mcnab wrote: Mon Mar 23, 2020 8:33 am hi mate
cheers roger mcnab
Finally I have find for the other gear , that's to drive oil scavenge pump for dry sump system used on sprites sebring
The second gear on the cam was to drive a dry sump pump. This was used commonly in single seaters, but only very rarely in the transverse models.
Sorry, I was a bit late there :)
tom17
Post by tom17 »
mk1 wrote: Mon Mar 23, 2020 10:24 am The second gear on the cam was to drive a dry sump pump. This was used commonly in single seaters, but only very rarely in the transverse models.
thanks for your reply, all comments are welcome
roger mcnab
well it would be hard to run a dry sump in a mini where would one put it like the sprite has plenty of scope
well cheers roger mcnab
rpb203
Post by rpb203 »
Didn't Mark LeMaitre's car in the late '80's early 90's run a dry sump?
There are quite a few examples of Minis that were dry sumped. It's just that it never became particularly common.
