1275GT 8 port group 2
Hi ,
Here is my project for historic racing , a 1275gt group 2 ( period G2 ) with cooper's engine and weslake 8 port cylinder head.
I made a replica based on the works 8 port clubman YMO 886J ( I know it was initialy build for group 6 but can raced in group 2 with minor modifications )
All parts from the engine are original special tuning.
I use a modified round nose mini to build my GT ( a mk5 body that will be converted to mk3 )
The engine rebuild is in progress.
I will share next steps !
Re: 1275GT 8 port group 2
that is an unusual head have never seen one like that were many made
cheers roger mcnab
cheers roger mcnab
- Been thanked: 3 times
Thanks,
Today I have received the left and right tank as fitted on rally car.
Normally I can use a third fuel (bag) tank to have a better autonomy like Works rally car , but I will wait to know more about the engine fuel comsuption, maybe 50 liters wil be sufficient to race today ( rallies are more shorter today ).
I have find also original repro of C-AJJ4020 wings extentions for 1275GT groupe 2 as describted on homologation form.
- olfrjf
that looks to be an excellent project ,with some rare parts used ,keep us up to date with pictures
long time gone
Today I have started to pre-assembling the engine , i have bought the engine dismantled as you can see on the first page.
I have checked the block and crank line , pistons clearance ( 0.0035in/0.090 mm , great !), timing and mesurate/control all the parts etc etc to prepare final assembly.
I have a question , I have see that the camshaft have two pinion , one for distributor , but the other one ?
If someone can tell me why ? ( I think it maybe for a pump ... )
hi mate
the oil pump is usually driven from the end of the camshaft what that other skew gear is for is a mystery
cheers roger mcnab
cheers roger mcnab
Finally I have find for the other gear , that's to drive oil scavenge pump for dry sump system used on sprites sebringroger mcnab wrote: ↑Mon Mar 23, 2020 8:33 am hi mate
cheers roger mcnab
The second gear on the cam was to drive a dry sump pump. This was used commonly in single seaters, but only very rarely in the transverse models.
well it would be hard to run a dry sump in a mini where would one put it like the sprite has plenty of scope
well cheers roger mcnab
There are quite a few examples of Minis that were dry sumped. It's just that it never became particularly common.
