Mmmmmm bolloxs
999 ORX
Mmmmmm bolloxs
Post by 999 ORX »
Any ideas folks? I just took my bean out and pulling out of a junction and it felt like it jumped out of gear and lost drive!!? Now if feels like it selects gears and the clutch is depressing but no drive!? It ticks over fine no nasty noises!?
Any ideas? It's running a ultra light flywheel, orange diaphragm, straight cut drops, quiafe atb diff, straight cut CWP straight cut box new drive shafts etc.. Its all new stuff? Ffs... One thing after another!
Any thoughts greatly welcomed!
Cheers chris
JC T ONE
Re: Mmmmmm bolloxs
Post by JC T ONE »
Maybe the spring, in the pressure plate ?
medwaybeat
Re: Mmmmmm bolloxs
Post by medwaybeat »
I had a similar thing twice. Does it make a bit of a grinding noise when in gear and you’re trying to drive it?
1 st time sheared all the splines on the clutch or it could have been the primary gear.
2 nd time sheared all the splines on one of the drive flanges.
I’d check the drive flanges first. Good luck
Pete
Has thanked: 39 times
Been thanked: 105 times
Re: Mmmmmm bolloxs
Post by Pete »
medwaybeat wrote: I’d check the drive flanges first. Good luck
Just thinking the same thing though normally there'd be the accompanying noise of the shaft still turning.
999 ORX
Re: Mmmmmm bolloxs
Post by 999 ORX »
Drive flange makes sence with the quaife, as it might act like a wheel picking up.. hence loosing drive.. Yeh it does make a bit of a noise.. Nothing like a shaft though... Mmmm
1071bob
Been thanked: 34 times
Re: Mmmmmm bolloxs
Post by 1071bob »
Is the speedo still working when you have it in gear with the clutch out? If its a problem within the diff the mainshaft [and therefore the speedo] would still be turning, If you have no speedo the problem lies elsewhere.
36inter
Re: Mmmmmm bolloxs
Post by 36inter »
Put it in gear and look at the drive shafts, if they are turning the problem is with the hubs, if they are not turning I suggest you dismantle the clutch, if its not here its an engine out job, hope its a simple fix.
guru_1071
Re: Mmmmmm bolloxs
Post by guru_1071 »
all good advice above, all i would add is dont just rush and put it in gear and start looking for the fault.
make sure its well chocked and that you have the means to stop it quickly if it suddenly finds the means to drive again.
running yourself over would probably put a lid on a bad day! :shock:
999 ORX
Re: Mmmmmm bolloxs
Post by 999 ORX »
Cheers for the suggestions,
don't worry guru Im not Frankie Baitmen of'a the mini forum..
999 ORX
Re: Mmmmmm bolloxs
Post by 999 ORX »
I haven't yet decided to investigate the problem but I was just wondering is it a common thing to sheer of the pinion gear on a A series box? As begining to wonder if that's whats happened?
Matty
Re: Mmmmmm bolloxs
Post by Matty »
The flywheel hasn't come loose has it?
Mine came loose once and selected gears fine but obviously wouldn't drive. The revs did drop dramatically when the clutch was depressed though.
Andrew1967
Re: Mmmmmm bolloxs
Post by Andrew1967 »
Mainshaft nut come undone and the pinion gear has slipped out of mesh with the crownwheel?
It will still engage gear and the speedo with work but there'll be no drive. I've seen this happen on a Metro in the past.
618AOG
Re: Mmmmmm bolloxs
Post by 618AOG »
Andrew1967 wrote:Mainshaft nut come undone and the pinion gear has slipped out of mesh with the crownwheel?
It happened to me once! A new lockwasher and a dose of Wurth threadlock did the trick.
999 ORX
Re: Mmmmmm bolloxs
Post by 999 ORX »
Hello,
I've not touch the mini since it balls up, so yesterday I decided I would tidy my garage out to make a start on it. So I pushed it out and did my tidying up. Whist it was out, I thought I'd fire it up as I'd not heard it for a while, anyway I sat in it and to my shock it actually drove!? What's going on!!!? Aliens!!?
Haha, I don't think it's fix really but I'm a bit flummoxed by it.. Can I rule out pinion gears? Clutch area? When it happened I ask my brother who was with me to check that it was moving the clutch arm and he said it was.. It was just like a mini with a dodgy 2nd syncro, it just jumped out as I was pulling away, then wouldn't drive!? So i pushed it home and shoved it the garage until yesterday..
Any ideas now!? With that in mind!
I've thought that it could be the plunger getting stuck in the housing, master cylinder acting like a one way valve.. God only knows!
tomkidd
Re: Mmmmmm bolloxs
Post by tomkidd »
999 ORX wrote:Hello,
Gremlins! Does sound very odd.
JC T ONE
Re: Mmmmmm bolloxs
Post by JC T ONE »
Or the hose ?? have seen this before, a piece of rubber blocks the hose,
and the clutch arm wont return.
