Barn find MK 2 Rally car
e-type
Re: Barn find MK 2 Rally car
Post by e-type »
Now with wheels
e-type
Post by e-type »
Pre owned :-) Avon CR6ZZ tyres, and patina wheels
e-type
Post by e-type »
Not much done the last 2 months, but the gearbox is now ready. All the parts from the old box is reused in the "new" housing.
So it is genuine ST sc/cr 4 synchro, with Salisbury LSD, and 4.26 diff ratio. Also the homemade "splash plate" went back in.
e-type
Post by e-type »
1:1 Jack Knight drop gears with Timken bearings
e-type
Post by e-type »
The tough gaskets will be used :-)
e-type
Post by e-type »
Sunday, I started the engine build, I did fear, that the valves could hit the pistons, so I fitted the cylinderhead, without the gasket, and sure enough the exhaust valve hit the piston just before TDC.
Fanfaniracing
Post by Fanfaniracing »
I like this a lot! What cam do you use?
e-type
Post by e-type »
It is the Minispares C-AEG311 Rally evolution, duration 306 in and 300 out timing 53/73 in and 74/46. This cam has more exhaust lift.
but I do have another, that came with the car, and it should be of Jim Whitehouse design, and is also duration 306 in and 300 out, but 48/78 in and 75/45 out.
e-type
Post by e-type »
These useable std size forged pistons, came with the car, the Cut outs for the Valves needs to be about 1 mm deeper. Anybody knows of the piston brand HG?
wantafaster1
Has thanked: 4 times
Post by wantafaster1 »
Possibly " Hepolite and Grandage"
Not sure if I have spelled that correctly
GRAHAMC
Post by GRAHAMC »
Hepworth and Grandage
wantafaster1
That's it!
r.tec
Location: Bad Muenstereifel (D), 30km to The Ring, 80km to Francorchamps
Has thanked: 7 times
Post by r.tec »
Hepworth & Grandage -> AE Hepolite -> Federal Mogul -> Nüral
e-type
Post by e-type »
After 3 weeks, working in Switzerland, it is nice to be back home in the garage. I have had a closer look, at the 8 port cam installation. With the AEG 625 "S" rods, a lot of the head needs to be removed from the bolt, to clear the cam.
e-type
Post by e-type »
Fortunately, it is a set of AEG 177 conrods, I have chosen to work on for this engine. Look have much lower, the bolt sits in the conrod. Is it always like this?
251 ENG
Post by 251 ENG »
Yes all AEG 177 rods are like that , the original BMC rod bolts were shorter
I believe BMC changed the rod design because some rods failed
e-type
Post by e-type »
After som turning and milling, the conrods is now ready.
For the 177 rods the new ARP bolts have been shortened by 3mm.
Before they where about 680g, and now 600g
Very nice job!
I love your Con Rod balance :)
e-type
Post by e-type »
Fitting the pistons
e-type
Post by e-type »
After trial fitting, with the chosen cam, I made the pockets 0,70mm deeper
