62 Austin Seven Cooper
Re: 62 Austin Seven Cooper
VERY, VERY NICE INDEED!
Fanfaniracing
Post by Fanfaniracing »
Charlynsane wrote:Fantastic work!
What's your calipers?
What sort of bonnet will you fit? could be better to keep the original bonnet with short stack?
I guess the calipers are very early Minispares ones?
Whe will try to make a Airbox with remote Filterbox. Will post when finished... Only running on Stub stacks without filter is not an option for me. I want to keep this expensive engine as healthy as long as possible...
Richspec
Post by Richspec »
you can use a blank filter back plate and a sausage filter (like on the minispares injection kit) and it fits under a standard bonnet.
Richspec
Re: 62 Austin Seven Cooper now 8 Port
Post by Richspec »
I take that back, I've just looked back and I had to take metal out of the slam panel to make it work.
Fanfaniracing
Is there any possibility to shorten the inlet manifolds? They are very thick at the connections...
Fanfaniracing
So! Another busy weekend!
I managed with my panelbeater to get thot beautifully crafted Airbox! The bonnet just got minor modifications so it will close and from outside you just see nothing!
The bonnet is now secured by two works style leather straps.
The Box is connected with a Hose to a modified Automatic Aifilter Housing wich now has a nice K&N Filter element inside.
I would like to calculate the HP capacity of this Filter Element. Does anyone knows the formula?
Regards
Fanfaniracing
And the bonnet...
kit of bits
Post by kit of bits »
I’d love an 8 port on amals really nice project..
roger mcnab
Post by roger mcnab »
hi a guy here in australia had a simular set up but used dellorto pumper carbs like ducatis have went very well just a thought i remember him trying to sell it to me for my old mk1 a long time ago
cheers roger mcnab
Fanfaniracing
After trying to set up the carbs and not arriving to a satisfactory result, i decided to go for a Weber
Setup.
The tread from an other forum member gave me hope to build up a setup that works...
Here the first pics of the manifold build.
roger mcnab
you will need to put some spacers to isolate the heat transfer so there is no problem with that side of things i am using 4 idf webbers on the rover v8 for my unipower gt replica
amals were a pain to tune especially those concentrics thats why that guy used the dellortos
keep up the good work it will come good
cheers roger mcnab :D
Fanfaniracing
After a very busy week at work before Christmas, i found some spare time to continue my manifold.
It took an awful time to get the holes right the first time.
With the flanges set up and the tubes formed from 40mm to 30mm it only needs a good weld tomorrow...
Last edited by Fanfaniracing on Sun Dec 22, 2019 11:18 pm, edited 2 times in total.
Oneball
Post by Oneball »
Have you checked the clearance to no 3 plug?
Fanfaniracing
Oneball wrote:Have you checked the clearance to no 3 plug?
Not yet. But there is enough space between the tubes and enough flesh on the manifold to finetune it.
Once it's welded and face-grinded i will modify if needed to get to the spark plug...
Fanfaniracing
After welding the tubes on the head side, it was skimmed to suit and make an even base...
WHAT A BRILLIANT JOB!
Some really excellent fabrication skills on display there.
Fanfaniracing
So finally i got this thing working!
After the second flange for the webers was welded, whe put it on the mill again and skimmed both plates to reduce length and getting a smooth straight surface.
Back at home i managed to refit the manifold. It needed some fine tuning to get access to the nr 4 sparkplug. i then modified both carbs to put them as close together as possible.
With the fuel line connected the engine fired up first time with a big roaring from the Webers!
Tomorrow i will connect the both carbs together and connect the throttle cable.
I guess the bonnet needs some modifications now...
I give a big thank to thomas who was very helpful with his pictures and information and my mates at work helping me with the weld and mill!
Fanfaniracing
mk1 wrote:WHAT A BRILLIANT JOB!
Thank you mark!
A good machinery at work makes life easier sometimes...
A fantastic installation!
Glad to hear it sparked up first time.
roger mcnab
bonnets just have to make life just that little bit more complicated a bit of head stratching and a cuppa and the solution will appear and all will look great a really well sorted job
cheers roger mcnab
