Mk1 S recent purchase cylinder head quetion
uncle 997
Post by uncle 997 »
Hi All.
Recently purchased a 67 mk1 S in bits.
The car was stripped in the early 80's and partially restored.
All the rare S parts are with the car and I will restore it back to concourse condition.
The cylinder head has been ported and has big valves etc.
It is a 940 casting with 12g 1805 in the usual place,but on the back of the head just under the centre exhaust port it has RTC 127 stamped on the mating face.
Does anyone recognise the stamping code and identify possibly which company ported it ?
whistler
Has thanked: 10 times
Re: Mk1 S recent purchase cylinder head quetion
Post by whistler »
Think that head wasn't fitted until the MK3 in late 69/70 so probably wrong for your 67 engine if you want to keep it correct.
AndyPen
Been thanked: 21 times
Post by AndyPen »
Bit of a long shot, but didn't Turner Engineering use RTC codes? All I can find online is that they do LandRover stuff now?
Oneball
Post by Oneball »
AndyPen wrote:Bit of a long shot, but didn't Turner Engineering use RTC codes? All I can find online is that they do LandRover stuff now?
RTC.... is a Land Rover part code like 12G...
Has thanked: 25 times
Been thanked: 29 times
One little point might clear this mystery up. Is the RTC mark RAISED, as in cast-in or is it recessed, as in engraved or stamped in?
GraemeC
Post by GraemeC »
He clearly says stamped, not once but twice.
Sorry I spoke........
