Barn find MK 2 Rally car
Re: Barn find MK 2 Rally car
ADO 16 radiator
Last Friday I picked up the rest of the parts, that came with the car. It looks like the old war horse has been used in anger .
More evidence of a hard life cam follower and pistons
It will need new brake parts, to get it going, but luckily i found these in some of the many boxes with spares that came with the car
maybe I am lucky, this box was among all the many parts that came with the car
Saturday, I pulled out the engine.
Reason why they stopped using the car: broken remote housing, and diff cover
Are you nuts!! , Cooper S thin flange engine block
Drop gears with Timken bearings, and nicely engineered plate
After honing the rusty cylinders, the pistons cam out, nice polished Cooper S conrods
EN40B 1275 S crank and 731 cam
Genuine LSD, but never seen these output shafts before.
According to the seller, the driveshafts, should be Jack Knight, but the output shafts looks like a mix of hardy spicer and pot-joints.
Any info on this please?
- r.tec
- Location: Bad Muenstereifel (D), 30km to The Ring, 80km to Francorchamps
- Has thanked: 7 times
- Been thanked: 3 times
Do not know exactly but I remember that in one of the ancient David Vizard "Mini Technical News" he wrote that someone in Denmark used modified Saab driveshafts. Have to look through all my copies.
Got the perfect engine/box thin flange just up the Kattegat! Thurston@online.no eller 004793887331 mvh B
Looks like someone has welded a turned down pot type joint onto a salisbury LSD type output shaft , you can just see the weld .
Yes after cleaning, I can see, that is what has been done.minimad wrote:Looks like someone has welded a turned down pot type joint onto a salisbury LSD type output shaft , you can just see the weld .
Maybe only the shafts are Jack Knight.
There is still evidence from the last Rally it did some 35 years ago in Faxe Kalkbrud. Faxe is the town, where they make Beer, but also have a large limestone quarry. The white stuff is everywhere under the car.
I think it will need a recharge
