- Andrew1967
Little bit of progress in my domestic garage in last few days ....
Front wings self tapped and clamped in place. A few things to alter here and there, mostly on the n/s inner wing rail that isn't quite right. Overall, I'm quite pleased with the initial fit.
Front panel modified to Mk1 spec. including changing the slam panel to a Mk1 panel from the original front panel from a previous build.
Bonnet has been used as a table in the past to red oxide prime small bits and pieces
- Has thanked: 28 times
- Been thanked: 30 times
Geeat to see more of it. I need a fix of crack-HOY every couple of weeks or depression starts to set in.....
- coopertim
- Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
Looks fantastic Andrew! Can’t wait to see HOY in Surf Blue &White!
Looks very nice, are you changing the indicator plinths as well,
- Andrew1967
Well I wasn't planning to but the general consensus of opinion dictates that I should
I think I can rescue the ones from the panel I tool the slam panel section from
If you don't, you'll always regret it Andrew. I did them on mine and although it was a bit of work, I was glad I did. A Mk1 with Mk4 front always looks wrong to me. I also swapped the landing panel because the late one os SO wrong. Heritage ought to be ashamed of themselves for pretending that their "Mk1 front panel" is anything like correct.......
Great to see some more progress
- Andrew1967
I suppose we should be grateful that there is such range of panels available, but it would be better if they were a bit better described so as to not fool those of us who are not quite as well educated in all things Mini.
Anyone know the change point / date for the indicators ?
Or was it mk4 onwards ?
Looks great Andrew
Thank you
Looks great Andrew
Thank you
- Andrew1967
OK, I'm going to do it otherwise I'll never hear the end of it
Well done Andrew. You know it makes sense You've already done MUCH harder jobs on HOY. I would post the pictures of how I did mine but I seem to have "lost" them. They were also on my old restoration thread on the old MCR forum.....Andrew1967 wrote:OK, I'm going to do it otherwise I'll never hear the end of it
Hahah! Yep, you’re straying from the ‘factor fresh’ look a bit there Andrew.Bart Smith wrote:Nice. Those gaps are way too good though.
Looks great!
- Andrew1967
Yeah maybe, but remember its only held on with self tappers and mole grips so may move when welded up
- Andrew1967
OK, so does this satisfy the plinth police
Yes worth the effort, small difference but noticeable
Well done Andrew. I'm much happier now You can now wander around all those summer car shows looking at other people's Minis whose owners didn't bother doing that. And feel better about yours.
- Andrew1967
Thanks Darren and Richard
It was a bit of PITA but as said, was worth it in the end.
Andy, surely that plinth rectification or retro-modification deserves a small tech article in its own right. To be honest, I've never even noticed the difference before I read it here and made a couple of comments. But MUST be worth a separate write-up for other restorers......... when you've got time!
Hi Andrew,
I just read every 40 pages of the resurection of your 65 Cooper S and just want to tell you "Thanks you" Really good job you have a great spirit with the minis (as for this forum) thanks for that !
Cheers for Dunkerque (FR)
Pierre
Pierre
- Andrew1967
Hi Pierre,
Welcome to the Mk1 Forum and thank you for your kind comments about my project.
It is and has always been my aim to be open and transparent about the rebuild of HOY 500D. I have no intentions of selling it once finished and therefore have no need to hide anything about it.
Hopefully the project and thread will be an inspiration to other people who have what many consider to be a 'beyond hope' restoration project, to show what can be done, even in a 'domestic' garage !
This forum is by far and away the best Mini forum you will find for help and knowledge
