FAN METAL MK1 COLOR ORIGINAL - YELLOW PAINTING CODE
- ACDESLIONS2
Hello
I'm looking for the exact color to complete the restoration of my FAN MK1 metal
Would anyone have the reference PANTONE or ? for the Orignal yellow painting please ?
thank's a lot
Regards
thank's a lot
Regards
- Has thanked: 59 times
- Been thanked: 60 times
Re: FAN METAL MK1 COLOR ORIGINAL - YELLOW PAINTING CODE
I think that this has been answered many times on the forum. Have a look on the search for FAN COLOUR
- ACDESLIONS2
Hello
Thank's a lot for your answer
I found that with research "
Hi Warwick,
OK, here is what I reckon for a Mk1. From memories of long ago and more recent observations ! The engine and trans appear to have been almost completely assembled prior to painting. Fitted after painting was the distributor and clamp (plain), carburettor and abutment plate (plain), coil (plain, although the coil mounting on the dynamo/generator was green) waterpump pulley and fan (golden yellow). The serial number plate was often masked by a piece of tape with torn ends placed over the plate. The gearbox/transmission housing was rather roughly done, more like hit with the spray gun when the engine was painted but the clutch housing was painted. The underside and lower parts of the trans had nothing more than green overspray on the aluminium. On my Cooper S engine, the clutch operating arm looked like it had been black when fitted and was not completely covered in green. Going by what I could see the clutch slave cylinder was green but mine had been replaced. Many seem to make the mistake of leaving the starter and dynamo end plates unpainted. I don't think they were ever like that ex factory. "
RAL 1004 = Golden Yellow
it is right for us please ?
Regards
Hi Warwick,
Regards
- Has thanked: 16 times
- Been thanked: 45 times
If you are doing the lot in one go, I've found that Rover Inca Yellow is very close indeed. I've a heritage fan on an Inca yellow pulley and no one has ever spotted the very slight hue difference.ACDESLIONS2 wrote:Hello
Hi Warwick,
Regards
Having said that, my old tropical fan and the old fine blade one are slightly different shades too. The original fan is more yellow than the tropical, which is more golden like the Inca Yellow - hence my choice.
I was surprised when stripping my old 970 down that the spacer plate was black, so maybe someone might comment on that too.
- Toby
- Has thanked: 7 times
- Been thanked: 3 times
I have that on my 61 and on my 1071 too and on the nos ones that I have.AndyPen wrote:I was surprised when stripping my old 970 down that the spacer plate was black, so maybe someone might comment on that too.
With regards to the colour yellow, RAL 1003 Signal Yellow works well too
Compare the heritage fan's yellow with the Rover Inca Yellow on the pulley if it helps ![Wink ;-)](./images/smilies/icon_e_wink.gif)
- ACDESLIONS2
hello
Thank you very much to all of you for your precise answers
I tested with an engine paint ( C71 Speedline Colour YELLOW bought from Somerford) but the color is to 'GREEN'
I try to paint again the Fan with RAL 1002 or 1003
Best regards
Best regards
- coopertim
- Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
- Has thanked: 17 times
- Been thanked: 6 times
I’ve always used Inca Yellow, it’s the Triumph shade I use.
- ACDESLIONS2
Hello
Information in John Parnell book Original Mini Cooper
"the nearest modern Colour match is 'DATSUN DEEP YELLOW"
Josoa
Josoa
With all due respect to you Josoa and John Parnell, I’ve tried both and found the Datsun deep yellow far too dark. I agree with Andy, Rover Inca yellow is as close to the original as doesn’t matter
Over here I get it in Halfords
Alan
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
![Wink ;)](./images/smilies/icon_e_wink.gif)
Alan
- ACDESLIONS2
hello
The result
BLMC Inca Yellow (FAB/94)
thank's a lot for all answer and help
very best regards
The result
very best regards
Mine was black, but your original pic makes it look as if it was yellow doesn't it?
- Brett
- winabbey
- Been thanked: 13 times
I realise this is a very old post but while searching through some BMC Standards documents I came across this relating to the metal fan that mentions the colour specification - YL8. Thought it worth posting here.
- Exminiman
- Has thanked: 36 times
- Been thanked: 24 times
Personally, I would of wiped the fan with thinners and put it back on, looks ok to me, lots of patina....
- Hipwell
Interesting, Search engines bring it up as YL.08, can't find any images of anything painted in that colour. Wonder if its recognised by my local supplier.
- Been thanked: 7 times
Inca Yellow with a white undercoat is usually spot on.
I doubt that any paint code would match to the original BMC YL8
