Morris Cooper grill slat support orientation
Re: Morris Cooper grill slat support orientation
Great stuff Winabbey. With drawing,s like that i think someone should start remaking them, as would save me trying to make 2 without the skill,s or equipment. Here,s hoping, Tim
- Has thanked: 66 times
- Been thanked: 64 times
If that were me rebuilding my grille, and not being a sucker for originality - or punishment - I'd just get 2x suitable lengths of stainless guillotined off to thickness, clamp them together, and drill the holes as per the spec. Bent joggled end to dog-leg shape and rivet grille together. That's it, for life. That's just me I suppose.
- Been thanked: 33 times
Tim, I have a couple of original stays if you want them, also have a couple of my reproduction end plates if required. I haven't got around to making the stays yet.
- winabbey
- Been thanked: 13 times
If you want to check the dimensions and hole positions of your reproduction end plates here's the engineering drawing for it.1071bob wrote:Tim, I have a couple of original stays if you want them, also have a couple of my reproduction end plates if required. I haven't got around to making the stays yet.
Cheers Winabbey,
That looks easier than what I had to start with![Laughing :lol:](./images/smilies/icon_lol.gif)
Thanks Bob, yes 2 stays and end plates would be great. Mine look abit like your photo, although the slats look like new so deserve new fitments. Can you Pm details, thanks so much Tim
- Has thanked: 16 times
- Been thanked: 45 times
Doug, I can see why you are Mr BMC publications! Together with Bob you'll put heritage out of business at this rate. Top work!winabbey wrote:If you want to check the dimensions and hole positions of your reproduction end plates here's the engineering drawing for it.1071bob wrote:Tim, I have a couple of original stays if you want them, also have a couple of my reproduction end plates if required. I haven't got around to making the stays yet.
As above.... Here, here. Great info and thanks all.
Good lord, those look like they were discovered in a cave with the remains of an ancient hominid.1071bob wrote:Cheers Winabbey,
- Has thanked: 9 times
Is anyone making the slat supports? Could do with a pair as mine have the ends cut off?
