Looked for week then found the photo !!! Here is my B series in a mini
, Space frame car , BUT all mini running gear , Front subframe was chopped a fair amount , cannot remember much about it as its 45 years + , mini swinging arm on the back and i think Triumph herald springs and shockers ??? , the engine fitted ok BUT it was front heavy , meaning most of the weight was forward of the front wheels , i think i used two shorter drive shafts or maybe two short AD16 , i remember welding the mini yokes to the 1800 yokes , but probably a fair bit of butchering , gearshift was ok because its cable
, engine came out of a 1800 land crab £30 , rebored + reground crank , I fitted bigger valves and gas flowed , full race ST camshaft , Twin two inch SUs , i had to cut pockets in the block for the valves to clear on full lift , was it any good , NO , good talking point though , Built the car and everything else minimum tools , This included Stick welder , Grinder , 7lb hammer , hand drill and not forgetting the wrecking bar nothing else , Sold it to a grass tracker and he put the engine back in a landcrabb , i heard he did OK
The photo was taken at Marsh Lane Bomber track , Near Eckington , Sheffield . Happy days , also we went to Doncaster , York road . got me down as G.Allan ??
