Hi, what type of switch do I need for under the binnacle and also what wiring or type of bulb holders are needed to lite the speedo up?
Just received my binnacle from nippy cars and carnt tell you how good they are! Amazing reproduction quality. Top marks..
Binnacle switch
- Has thanked: 15 times
- Been thanked: 16 times
Re: Binnacle switch
Autosparks do the metal clip in bulb holders if you want new or I will have some kicking about.
eBay item 123522975584 shows a switch.
- johnv
Re: Binnacle switch
Let me know if you find a source, thanks
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
- 111Robin
- Been thanked: 17 times
Re: Binnacle switch
viewtopic.php?f=5&t=22964&hilit=Switch&start=10
Lucas part number 5L31. Also used on the ADO16 and probably other BMC models.
- Aginley
- Has thanked: 5 times
- Been thanked: 3 times
Re: Binnacle switch
Found something the same from somerford
- iain1967s
- Been thanked: 7 times
Re: Binnacle switch
Early single dial speedo has a square toggle each side - they are hard to find now. My Mk1 S oval dash has a more rounded toggle. Whereas BCA4312 is a flat toggle, more like the windscreen wiper switch.
I think, from left to right, the part numbers are: 13H303, 5L31, BCA4312
