authi mini 1000E 1969
hello
I am jeroen from belgium and i purchased a authi mini 1000E of 1969 a couple years ago.
i have now started cleaning up the car . There is not so much rust at al , only the front floorpan on the drivers side will be replaced.
The doors will need a reskin to .
The bootlid is a different story . It is repaired with almost a centimeter of putty. Therfore i removed the skin to work on it from the inside.
Re: authi mini 1000E 1969
some pictures:
By naturalkoncept at 2009-06-10
By naturalkoncept at 2010-04-15
By naturalkoncept at 2011-05-08
I removed the rust from the floor and painted it in red mainy ( with lead)
some special authi parts:
By naturalkoncept at 2011-05-10
engine:
engine:
unfortunately the bonnet badge is missing and i'm looking for one.
If someone got something please feel free to contact mee!
a picture of the badge :
By naturalkoncept at 2011-06-15
- Simon776
The 1000E was a nice car - came with S wheels and brakes as standard as well as Elf style wood dash.
One of the problems is that the leather seats (which are different to a 1275C) seem to suffer very badly in the Spanish climate.
- decarcer
jeroendewil wrote:hello
hi there jeroendewil
nice mini... but I am sure you have an AUTHI 1275C and not a 1000E.
there are some hints that explain this:
1.- blinkers at the front wings... the 1000E never had them... only the 1275C
2.- the "dome" at the door bins... only on the 1275C... intended to avoid the seat flipping forward when the door is closed.
3.- the tool bag... the only spanish mini with a tool bag was the 1275C.
4.- the bonet light... only present in the 1275C
if so... you have the most valuable AUTHI nowadays... congratulations!!!!
She deserves a proper restoration... there were no more the 1600 built units.
If you provide me with the shell number and the engine number I can tell you if it is a real 1275C with shell and engine matching numbers
Guille.
www.trececlasicos.es
i'am quite sure it is a 1000 E because it is a 1000cc engine with a 12g201 head ( don't know specs about this head)
I also have a 1000 E sign as you see on the picture of the bootlid.
The seats are in very good condition.
I also dont know if te toolbag belongs to this car or purchased afterwords.
it also has the bonnetlight fitted but don't know how it works same on the light in the boot.
Also one side of the dashboard is rotten and i'am looking for one to replace it .
it will for now only be a temporary restoration to prevent further rust .
I'am still studying at the university so i can't effort a complete restoration yet.
Decarcer you have pm
- decarcer
jeroendewil,jeroendewil wrote:i'am quite sure it is a 1000 E because it is a 1000cc engine with a 12g201 head ( don't know specs about this head)
The bonet badge, very difficult to find, was common in both cars, the 1000C and the 1275C.
The boot lid was as well common to both cars, and the 1000E badge does not mean is a 1000E, but just a 1275C in wich the bootlid had been replaced using a second hand one from a 1000E....
The engine might be a 1000cc, but this does not necesarily means that the car is a 1000e. The engine could be replaced in those 40 years of life... indeed, this was quite common here in Spain.
This is why, if you provide me with the engine number and shell number, I can tell you more about the car.
More detalis about a 1275C... the lids for the rear bins.... this was a very particuar feature of the 1275C. None of the other AUTHIs had them.
The boot light was operated from a little swich, located in front of the petrol tank. Post a general picture of the boot and I will tell you if the swich bracket is there or not.
Did not get any PM... try again
Guille.
- decarcer
a thats why the bracket is for . i was already wondering what it was. so i need to find a switch fot that .
some extra pictures:
By naturalkoncept at 2011-06-17
- decarcer
[quote="jeroendewil"]a thats why the bracket is for . i was already wondering what it was. so i need to find a switch fot that .
[quote]
And the dash seems to be the one for the 1275C... try to post a general pic of the dash... The 1000E dash was also wooden made, but covered the whole width of the dash, and had to little doors at both sides...
The car in plenty of good details... the lifting jack is also the original!!!! quite rare to fond nowadays
[quote]
Guille.
the dash covers the whole width . But i have removed the 2 sides for now because they were vere bad . The plan is to lat them be remade propper.
- decarcer
uuuppss... and I forgot that the 1275C should have rev counter... It seems you have a 1275C with some bits from a 1000E.... or viceversa... !!!
Guille.
it looks like a 1000E with the chassis of the 1275c then ?
Does it also have a automatic choke? there are some parts missing next to the carb
some things i found in the last years:
seems like the seats in the 1275 are also different then the ones i have
It looks to be a very interesting project, I am always amazed to see how the differing markets treated the Mini.
Maybe I should lookout for an Authi to leave at our villa ??
Those have got to be the best indicator warning lights ever fitted to a Mini
That is such a cool car so many small things, that makes it that bit extra special.
Are the jack & spanner, held in place by brackets to the bootfloor? looks like it in your pic.
