AEM91120:
Main bearings, 1275 2" mains. Heavy duty steel backed bearing for durability and long life. The bearings to use if you want it to last. The only bearings to use on a competition motor. Duraglide F780 ( Tri-Metal ) Sintered copper lead, lead plated,steel backed Nominal Composition Copper 74% Lead 24% Tin 2%
Looking at the A-plus type does not shed much light on it either:VP91120:
Main bearings, 1275 2" mains. Heavy duty steel backed bearing for durability and long life. The bearings to use if you want it to last. The only bearings to use on a competition motor. Mahle manufacture
VP91886:
lead indium bearing and is considered the best type available for race engines but most road cars will cover greater mileage on Glacier tin/alluminum type
So what type is the best to use in a race engine???AEM91886
Original equipment quality for factory built engines giving longer life expectancy on road cars under variable conditions of oil and use.These are the 1275cc mains as fitted to A Plus engines with the locating tab in the middle rather than to the outside edge as per Pre A plus engines Duraglide F780 ( Tri-Metal ) Sintered copper lead, lead plated,steel backed Nominal Composition Copper 74% Lead 24% Tin 2%
Rich?
