Converting MPI to carb!!??
mk1rally
Post by mk1rally »
I know in theory this shouldnt be done....but why not. Could I still run the SRS element of the ECU but bin the ignition and FI?? Just thinking for the future.
Does the block even have a hole for the dizzy drive or could I use the coil pack, trigger and something like a mega jolt or DTA?
coop12g295
Re: Converting MPI to carb!!??
Post by coop12g295 »
Theres no hole for the dizzy its blanked off in the casting
mk1rally
Post by mk1rally »
but I could use the trigger for another system...or could I even turn off the FI?
Giff
Post by Giff »
What do you want to achieve?
You might find this link helpful
http://trigger-wheels.com/store/index.html
guru_1071
Post by guru_1071 »
it would be easy to do, but you would have to use an aftermarket ecu and loom. it would probably be easier to mount the pickup on the pulley as most aftermarket stuff uses a 36-1 method of counting where the mpi doesnt.
the specalist components system is very good, and they have devloped a ecu to 'map' a spi, so it may be worth having a word to see if they are working on an mpi version.
the lack of dizzy hole is no problem.
the srs uses its own ecus though, but i dont know how this interlinks into the main engine ecu (or even if it does)
