What spares should you have on the shelf?
Dearg1275
Post by Dearg1275 »
If you have a Cooper S and use it, what sort of stock of spares should you have tucked away if you want to avoid frustration when something needs fixing?
minimans
Re: What spares should you have on the shelf?
Post by minimans »
I wouldn't stock anything. parts availability is pretty good for new and used parts via the internet these days, so why tie up your money? The only benefit is buying them now may be cheaper than in the future but who knows? Plus sod's law will come into play that says you won't actually have the part you need when something does break!!
Andrew1967
Post by Andrew1967 »
Minimans is probably not far off the mark but ....
I would certainly keep a couple of rear wheel cylinder kits in stock. Rear cylinders are terrible for sticking up through lack of use. Sometimes you can get away with just freeing off but other times new seals are required.
Usual service items of course.
That said, I buy anything I see that either I need, may need or know someone else will need, if the price is right :roll: :lol:
dklawson
Post by dklawson »
Points, condensers, spark plugs, cap, & rotor... maybe a set of radiator hoses. Beyond that, keep a collection of parts you find interesting and/or want to have for future trading.
Doug L.
Daz1968
Post by Daz1968 »
I just collect nos spares like bearings, rubber gaiters etc as most the new ones are not as good.
Other than that then if you are on points have spare points and condenser in the car
:roll: An woodrim steeringwheel :lol: :lol: :lol: :lol:
:geek: Kees
ricardo
Post by ricardo »
Oil filter, some oil, brake fluid, bulbs, points & condenser, maybe air filter(s)... focus on expected services and failures (bulbs, etc).
