Seat belt mounting point measurement
Andrew1967
Post by Andrew1967 »
Quick question...
Can someone give me the measurement, 'centre to centre' of the door pillar seat belt anchorage to inner sill seat belt anchorage point please.
Lower position door pillar anchorage - not earlier
cheers :)
Dearg1275
Re: Seat belt mounting point measurement
Post by Dearg1275 »
Andrew,
800mm, but off a repaired mk3.
Has thanked: 59 times
Been thanked: 54 times
If that's not what you want, tell me. I have a Mk2 restored using only original BL/BMC panels. And it'll tell you in inches too!
Andrew1967
Thanks David :)
Peter, if you could have a measure, would be appreciated, just to corroborate David's measurement. :)
Anyone with a car with original inner sill/s ?
This is just to give me another measurement to help assure alignment of the new floor.
Dearg1275
Post by Dearg1275 »
Andrew,
I have a 62 car with high mount with original inner sills. I can measure down to where the lower mount point should be and give you the distance from there. Hopefully someone else should come up with original measurements.
David
Andrew1967
Sounds good David, thank you :D
1071bob
Been thanked: 24 times
Post by 1071bob »
Here you go, I found the M/machine floor had the lower belt hole different to the original so I corrected that, it should be 76mm from the companion box.
Andrew1967
Thanks Bob, that pretty much confirms what I need to know :D
