Mk1 Mini Cooper Rally Car build
- R3Mark
Hi all I've been coming on this forum as a guest for a while now, looking at some of your other car builds and projects, so thought id Join myself, and add some photos of my Build, its a Mk1 Cooper Rally Car, were building it to compete in this years Mini Cup that runs within the HRCR Old Stager Rally Championship.. I'll add some photos, and if its of any interest then I'll keep them coming,
Thanks Mark
Thanks Mark
Re: Mk1 Mini Cooper Rally Car build
Welcome to the forum Mark,
I look forward to seeing & reading more about your car & it's build.
- R3Mark
Ok so here are some of the photos of the shell as its come out of primer, some of the panels weren't as smooth as id have liked, but I didn't want to use filler, so instead used some epoxy primer, or high build filler primer,
- R3Mark
- R3Mark
We then started to dry build the car, good job we did this as the hole in the bulkhead was not big enough to run the split carbs
I also wanted to add a few extra roll cage bars into the rear of the cage, so we'll do this, then we'll remove it to paint afterwards,
- rich@minispares.com
how come that you can run a cut bulkhead in a historic rally car?
its not allowed in appendix k racing or hscc class d / e and having a rcae car with one virtually makes the car illegal to run in anything
- R3Mark
Always a good idea to do as much dry building as possible, just makes the finished job look a lot nicer, nothing worse than drilling, or grinding a freshly painted shell, we moved the heater across to the left to gain more room, then we fitted the fire extinguisher and battery behind the seats,
- R3Mark
To be honest i wondered the same, but because there is proof, in photos, books ect that it was allowed or done back in the day, we are allowed to do it,rich@minispares.com wrote:how come that you can run a cut bulkhead in a historic rally car?
I remember back in 1973! having the job of cutting the carb to build a
set of split carbs, as my mate could not bring himself to do it.
Happy Days .
Happy Days .
I know someone who very recently has cut a set of webers back to front..........
school boy error..........
(it wasn't me)
(it wasn't me)
- pad4
Hiya - welcome to the forum, welcome to the hrcr rallying, great to see another mini joining us all , joining the split weber crew (although i use all 4 barrels)
Car looks like its going to be a nice thing, just check out your roll cage floor plates with the latest regs before you get to paint.
What class are you running in ?
Pad
Pad
- R3Mark
Yeah thank you, hopefully it will be a nice little car, Roll cage plates, please tell me more, i was just using the plates that came in the kit with the cage,pad4 wrote:Hiya - welcome to the forum, welcome to the hrcr rallying, great to see another mini joining us all , joining the split weber crew (although i use all 4 barrels)
Pad
Class wise, I'm not 100% sure, i think its Cat 1 class B, up to 1300
- Has thanked: 4 times
Hiya Mark, I'm out with Pad4 and Lakeland997 this year, good luck. Not sure how far along the road you are yet, but the plumbed in extinguisher rules change in 2019.
Just giving you the heads up, might as well get the right thing. Good luck
Welcome Mark and good luck with the build it's looking interesting so far.
As Jeff says, there are a couple of us on here who are doing the championship. It was my first year in 2017 so it was a steep learning curve. My car build is detailed elsewhere on the forum.
You probably know but you'll need to get the car inspected to get a competition log book and also they're insisting that you have a historic log book this year, that's just a big form filling (and cheque writing) exercise then send it off with some specific photos. It does take some time to come back but the guy that checks them is also the championship scrutineer so he should prioritise it if necessary.
Did you enter the first round (AGBO) yet?
Cheers, Andy
I think what Paul is saying about the roll cage is that we can't see the plates (the ones with the cage are fine) under the front legs e.g. in this image:
Cheers, Andy
...'welcome to motorsport'.....Lakeland997 wrote: (and cheque writing)
- R3Mark
Lakeland997 wrote:Welcome Mark and good luck with the build it's looking interesting so far.
Cheers, Andy
Ahh yes, I see what you mean, they are there I promise,
Yes got an entry in for the first round, so really looking forward to that, just 1 more good day to do a few jobs and she'll be ready for paint, then a big push on with the build, was hoping to make the test day in Feb, but think that may be a little tight,
- Been thanked: 22 times
Looks like a good shell. No rain drip rails I note? We used to hack them off I must admit.
I sold my splitties a way back, one of life's regrets I'm afraid.
Looking forward to seeing how it progresses and thanks for sharing
