1964 Rust project
Frogeye61
Re: 1964 Rust project
Post by Frogeye61 »
Glad you mentioned that with roof sound deadening. I had originally planned not to use it on my red 64 Mini, but I suppose the weight penalty is probably acceptable.
My Frogeye rear deck panel did this when first stripped, but after all the necessary plastic padding it no longer needed additional damping. (The car was an absolute mess). With this blue Mini project roof being new and straight, it will most certainly need a damping mat.
Thank you.
Mk 2 Super Deluxe
Post by Mk 2 Super Deluxe »
Great write up, I am about to start a very similar rebuild of a Mk2 Super Deluxe. The photos you have posted have been really helpful
Keep the updates coming
Paul
Frogeye61
Post by Frogeye61 »
OK, I'm back from a wonderful vacation in the Kingdom of Denmark. Exciting! Well actually I just went to my modern summer house for a week, back home for a weekend to celebrate my 25th anniversary, on to the "primitive" summer house with no electricity but on the beach. But, it rained most of the time, and the temperature wasn't exactly summer-like, and the water was way too cold to swim. The seafood was excellent though.
Heck, even this morning I had to wear a sweater while riding my bike to work. 14th August!!! Really! Everyone else is having record heat and drought. They took all my summer warmth.
Anyway, last night I got to do a small bit on the blue Mini, first time I touched it in three whole weeks. I welded up the back of the right door step panel, which has already been measured up and tested with the door and weather strip in place.
We will be back to our standard routine starting this week.
ImageIMG_20170812_173456 by [url=https:[email protected]<script data-cfhash='f9e31' type="text/javascript">/* */</script>/]frogeye61[/url], on Flickr
Frogeye61
Post by Frogeye61 »
Well, unfortunately both Peter and Tim were detained at the office or whatever. So I just had to do it myself.
The door went on and off quite a number of times, making sure everything fit right. Step panel was tacked at the front then door tested. Hinge holes filed so the door is just right, Inner A panel tacked at the bottom so the door fits solid. Door opening front panel tacked, adjusted to fit the door gap and then further tacked and then spot welded to the inner flange where the door rubber fits.
Now the door opens and closes properly with proper door seal compression (I think). Still need some finish welding on this before mounting the outer A panel.
ImageIMG_20170815_184545 by frogeye61, on Flickr
ImageIMG_20170815_184806 by frogeye61, on Flickr
ImageIMG_20170815_192426 by frogeye61, on Flickr
ImageIMG_20170815_193732 by frogeye61, on Flickr
ImageIMG_20170815_195037 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Last night I did the aforementioned small spots. Checked the A panel with door, reworked it a bit, then clamped it all and welded it in place. Mounted the door again and the front wing is just set in place in the photo. I still have to do the lower scuttle panel.
ImageIMG_20170816_200845L by [url=https:[email protected]<script data-cfhash='f9e31' type="text/javascript">/* */</script>/]frogeye61[/url], on Flickr
Peter came with a new original replacement front subframe and roll bar with diagonal, all from Mini Spares. (And then he talked a lot about getting a 450 HP engine for his 65 Mustang.) We painted the subframe with grey Epoxy primer, rather thick. I can now get my original subframe back which has been sitting in the car for months for dimensioning purposes. I have an engine and Cooper S brakes just waiting to go into it.
ImageIMG_20170816_190124s by [url=https:[email protected]<script data-cfhash='f9e31' type="text/javascript">/* */</script>/]frogeye61[/url], on Flickr
Frogeye61
Post by Frogeye61 »
Oh, good, another weekend. For a while I defied the wife and worked on the car instead of weeding the front garden. Alas it wasn't too long before the killer look. But while I could work I seemed to get a bit done.
Firstly the scuttle bottom plate. Please don't comment about the welding. It isn't that good but it holds very well.
ImageIMG_20170819_120922 by frogeye61, on Flickr
Then I mounted the - already modified - left side inner wing brace.
ImageIMG_20170819_120832 by frogeye61, on Flickr
The right side inner wing brace had not yet been modified. A 7 mil gap between the brace and inner wing must be removed.
ImageIMG_20170819_121025 by frogeye61, on Flickr
I cut a wedge from the outer edge:
ImageIMG_20170819_121639 by frogeye61, on Flickr
closed and welded it:
ImageIMG_20170819_122258 by frogeye61, on Flickr
grind smooth:
ImageIMG_20170819_122833 by frogeye61, on Flickr
and it fits like a champ.
ImageIMG_20170819_124643 by frogeye61, on Flickr
Then I started on the left side drip rail. Rail is made from 1.5mm sheet bent to 40 degrees. It may be a bit wide but that can be ground down later.
ImageIMG_20170819_185410 by frogeye61, on Flickr
Looking Good!
Frogeye61
Post by Frogeye61 »
Last night (again Tuesday) while one of us removed the front and rear subframes and fitted the spyd,
ImageIMG_20170822_192650 by frogeye61, on Flickr
Tim and I welded on the drip rails.
ImageIMG_20170822_194655 by frogeye61, on Flickr
ImageIMG_20170822_195027_01 by frogeye61, on Flickr
The metal is quite thick 1+1+1.5 mm and took three hits with the spot welder to obtain the heat necessary to hold the drip rail on.
ImageVID_20170822_195101 by frogeye61, on Flickr
Once the body was raised onto the spyd...
ImageIMG_20170822_200817 by frogeye61, on Flickr
we could roll it over...
ImageIMG_20170822_213129 by frogeye61, on Flickr
and the first thing is to weld the bottom of the right side rain gutter.
ImageIMG_20170823_075538 by frogeye61, on Flickr
Just try doing that while the car is upright.
ImageIMG_20170823_075530 by frogeye61, on Flickr
We can now easily access the rear valance and front floor welds.
ImageIMG_20170823_075517 by frogeye61, on Flickr
Also we need to clean the firewall and ready for painting
ImageIMG_20170823_075547 by frogeye61, on Flickr
Daz1968
Post by Daz1968 »
Or that it makes a lot of difference, but for information the drip rails have a double fold on the outer edge so not sharp, also normally bent on the ends, but looking good so far, brings back memories as the roof and gutter repairs were most awkward on mine.
Frogeye61
Post by Frogeye61 »
Ja, the original drip rail was folded over at the edge, but also thinner metal. The total thickness at the edge as folded was just about 1.5mm, so I just cheated, and got a more robust piece in the process.
One must also remember what I started with. In general, the history of components is just as important as the component itself.
ImageIMG_20160826_073230 by frogeye61, on Flickr
Callum
Post by Callum »
Wasn't the fold there to stop you scalping yourself when you got out the car? As it gets rid of the sharp edge.
Great work with all the welding, looks like your not far off finishing now
Frogeye61
Post by Frogeye61 »
This weekend I only had time to get this drip rail onto the right side roof drain channel.
ImageIMG_20170826_160327 by frogeye61, on Flickr
But then now that my front subframe is removed from the blue Mini, I decided to assemble the front suspension and my new Cooper S brakes.
I've been working on cars for more than 30 years, but in America we don't really have too many Minis, so I've never had the opportunity of rebuilding the front suspension on one. How come nobody ever told me how much p.i.t.a. it is to get everything together on the upper arm. Well OK I got it, also using Hi-Los. So far I only assembled the left side. These brakes are required in Denmark if using the 1275 engine and they certainly can't hurt if using a smaller engine.
ImageIMG_20170827_173946 by frogeye61, on Flickr
Yes, that's the short axle on the left side, wrong I know. I'll straighten it out later.
Frogeye61
Post by Frogeye61 »
Tuesday again. Now that the car is flipped over, and the bottom is easily accessible, Tim and I could install the rear valence, and with Peter's help we spot welded all the way around.
ImageIMG_20170829_195229 by frogeye61, on Flickr
ImageIMG_20170829_200912 by frogeye61, on Flickr
ImageIMG_20170829_202250 by frogeye61, on Flickr
We got Tim to clean the bottom of the foot panel, one of the few original parts of the carrosserie.
ImageIMG_20170829_195241 by frogeye61, on Flickr
ImageIMG_20170831_075340 by frogeye61, on Flickr
And from the bottom it's a bit easier to weld the front panel onto the inner wings.
ImageIMG_20170830_073241 by frogeye61, on Flickr
AndyPen
Has thanked: 16 times
Been thanked: 45 times
Post by AndyPen »
I am stunned - amazing work folks!!!
Frogeye61
Post by Frogeye61 »
Due to a weekend cycling trip to a local island and Peter being off to parts yonder, this week wasn't as productive as I would have liked. Tim and I did however further clean up the foot panel and mostly welded the corner with the inner wing.
ImageIMG_20170905_204001 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Again slow progress, however progress none the less.
Finished welding and cleaning the left foot panel, flipped the car over and welded the right side.
ImageIMG_20170912_213252 by frogeye61, on Flickr
Then we started on cleaning up all the front and rear suspension on Peter's Mini. Subframes are on their way to sand blasting and powder coating.
Frogeye61
Post by Frogeye61 »
This shell must at one point get some seam sealer and damping material. Seam sealer should have come last night but Peter was off to parts unknown (probably the far east) so he didn't bring it. I will wait until after the body is painted before applying the dampening material.
Turn sound on.
ImageVID_20170917_112433 by frogeye61, on Flickr
So Tuesday night Tim helped. Again while cleaning more of the rust off the footboard we found some previously hidden rust. Maybe we should have just changed this whole panel also, but we didn't. Well anyway, a quick drilling of the spot welds to the lower engine steady bracket revealed not only rust but a crack extending the entire width of this bracket. No wonder since all the spot welds were done in a straight line horizontally in the middle of the bracket.
ImageIMG_20170919_191521 by frogeye61, on Flickr
Cleaned, welded, and installed it looks good, just a bit more cleaning the plug welds needed in this image.
ImageIMG_20170919_194131 by frogeye61, on Flickr
One can just see the previously done carburetor clearance mod in the above picture. I was tired of trying to BS my way through this piece and decided to sort it. So out with the old...
ImageIMG_20170919_203934 by frogeye61, on Flickr
CAD design for the new
ImageIMG_20170919_203946 by frogeye61, on Flickr
and assembled.
ImageIMG_20170919_213145 by frogeye61, on Flickr
The entire foot panel is now cleaned with phosphor acid to help prepare the surface and prevent more surface rust until epoxy primer time.
Frogeye61
Post by Frogeye61 »
Productive evening last night. We removed the internal bracing, mostly to gain access to the inside of the vehicle.
ImageIMG_20170926_184147 by frogeye61, on Flickr
The inside of the B post was cleaned on both sides as this area is directly accessible to passengers reaching inside the side bins.
Lower panel cover plates and bins were readied for spot welding to the bins, rear seat, inner fender, side panel plates and door surround, though no picture of the plates.
ImageIMG_20170926_201128 by frogeye61, on Flickr
Roof gutter drains were cut in and formed. The gutter corners are not yet finished.
Drip rails were smoothed on all edges and corners. Gutters were checked and formed for straightness and curvature.
ImageIMG_20170926_205700 by frogeye61, on Flickr
ImageIMG_20170926_205822 by frogeye61, on Flickr
Floor panel welds and surface are now being cleaned inside of the body shell.
ImageIMG_20170926_210441 by frogeye61, on Flickr
baptiste
Post by baptiste »
lucky you are ! you almost have new shell .
https://www.flickr.com/photos/33241452@N02/37346943301/
but on this picture we can see that you didn't instal the closing of wheel arch yet .
how can you instal and weld it now ?
Are you able to slide the piece between the wing and the floor?
Frogeye61
Post by Frogeye61 »
No problem, As can be seen in this picture, it isn't welded yet between the floor and wing.. I have already tested it but for some reason we just haven't gotten around to fit it yet.
