Morris FIA Race Car
chris-pilling
Re: Morris FIA Race Car
Post by chris-pilling »
is it a weslake? looking at the picture again i cant properly tell if its upswept manifold on a arden?
alexdenevers
Post by alexdenevers »
I'm not agree with black colour on minis, I think it hides its curves. I would prefer a pastel colour, somewhere between grey and blue, with contrasting roof.
Vegard
Post by Vegard »
chris-pilling wrote:is it a weslake? looking at the picture again i cant properly tell if its upswept manifold on a arden?
It's definitely a Weslake. You can see the four core plugs in front where the ports would be on an Arden.
phil82
Post by phil82 »
chris-pilling
alexdenevers wrote:I'm not agree with black colour on minis, I think it hides its curves. I would prefer a pastel colour, somewhere between grey and blue, with contrasting roof.
once you go black you never go back.. haha
chris-pilling
phil82 wrote:here is another picture: http://www.mcm1980ev.de/component/optio ... l/id,3303/
cheers phil82, i thought it odd that someone would paint an alloy head i figured it must have been a weslake.. Good head, the kind i like.. haha :shock:
graham in aus
Post by graham in aus »
Could be an iron Weslake? ;)
phil82
Post by phil82 »
found another picture of that engine before the rebuild:
sorry for all that off topic.
Etienne B.
Post by Etienne B. »
Damn me, this engine is so beautiful ! another sleepless night ... :oops:
calex_fr
Post by calex_fr »
what is this fuel injected system, Lucas ?
Alex
Seventies Classic Club Trophy
phil82
Post by phil82 »
Etienne, did you have a good night?!
No it's not a Lucas, it's a Tecalemit, but as far as I know they have some problems setting up the injection system.
If anybody has some information on how to tune that and would like to share them, that would be great. I would like to forward them to Juergen who did the rebuild of that car/engine.
alexdenevers
Very interesting view of the engine management, especially pulse pump.
The engine doesn't suffered from overheating ? (fan blade..)
The setup above is "TJ" Tacalemit Jackson, lots of details on the main MK1 site.
http://mk1-performance-conversions.co.u ... l_carb.htm
About 1/2 way down.
graham.codling
Post by graham.codling »
assuming fuel pumps are in good running order switch pumps on see how much fuel is going into inake manifold pulling throttle bodies open not by the metering unit adjust pressure regulator to get a drip of fuel every second nip up locnut on regulator set pressure relief valve at around at about 15 pounds set metering cable so min of play be careful not to flood engine hope this helps regards graham
mehariman1
Post by mehariman1 »
Some news...
Image[/quote]
Image[/quote]
Image[/quote]
Image[/quote]
Image[/quote]
mastic
Image[/font][/color]
JC T ONE
Post by JC T ONE »
Looking good 8-)
Pete
Has thanked: 16 times
Been thanked: 39 times
Post by Pete »
I wouldn't have used unvented 'oversills' though , they just fill up with water and rot out. Amazing how many do still use them
mehariman1
Surf 1275 wrote:I wouldn't have used unvented 'oversills' though , they just fill up with water and rot out. Amazing how many do still use them
I totally agree whith you. An other people say me the same.
But it's a race car, so I would like to fix the roll cage to the floor and the bottom box for the rigidity.
Pete
Post by Pete »
Fair comment. :)
By the way talking of sills the worst case I saw of premature rot was on a really nice car that had been sandblasted and the sill sections were left filled to the top with (wet) grit. The new sills took less than three years to rot through. :shock:
JC T ONE
Post by JC T ONE »
No problemo, just drill a 8 mm hole, in bottom of each of the squares.
then water can get out, and more important, you can spray some thin penetrating rust preventing oil inthere 8-) and use one of these long "thingies" with a "shower" effect ;)
