Remote 22G846 / 22G1128 gearbox rear housing - Mini variant
docka
Re: Remote 22G846 / 22G1128 gearbox rear housing - Mini vari
Post by docka »
Great info dodge44 and spider, thanks.
If the tolerances were within Spider's recommendations, which method is the most reliable, magic wand diff cover or remote plus the (hard to find) conversion parts?
Has thanked: 59 times
Been thanked: 15 times
docka wrote: which method is the most reliable, magic wand diff cover or remote plus the (hard to find) conversion parts?
I would think parts for either would be not so easy to find and I don't think one is that much better than the other.
The big problem with any magic wand set up is that they have quite long levers with a fairly small slot in the bigger ball for rotational location. The slots and the peg wear quickly and badly and the smaller ball on the end not far behind.
The other down side of these set ups is that because of the angle of the gear lever, there is always has side pressure on the selector fork of the selected gear. Fitting hose or weights to them to quieten down any rattle they get, really only makes matters worse in the long run.
