Cooper S engine values
mr-marcos
Re: Cooper S engine values
Post by mr-marcos »
Sleeving can bring it back to standard bore. The advantage is harder wearing and you will never see them unless the head is off.
Rusty old S
Post by Rusty old S »
All my blocks have sleeves , Anorak Sleeves :lol: :lol: :lol:
graham.codling
Post by graham.codling »
Rusty old s I take it your small bore blocks have anorak pockets ;)
Supersonic
Post by Supersonic »
I say again, in my opinion, standard or +20 Cooper S blocks are the most valuable. Why would one sleeve an end of life S block when solid wall blocks are still available standard :?:
In 45 years working with classic Mini cars have I missed something?
Alan
251 ENG
Post by 251 ENG »
Nothing wrong with sleeved blocks if done correctly. :geek:
App K
Post by App K »
I've just built a 999s 8 port screamer on a machined standard A Series block, and quite honestly would have never considered using a 50 yr old s block for the build. Getting a standard good untampered block to bore to plus 20 would have really not been an option..
You can also still pick up standard A series blocks fairly cheaply, although the prices of these is starting to rise.
Pete
Has thanked: 51 times
Been thanked: 137 times
Post by Pete »
251 ENG wrote:Nothing wrong with sleeved blocks if done correctly. :geek:
Do race engine builders prefer to use sleeves anyway or is that just a 'must' to get down to size?
spoon.450
Post by spoon.450 »
I understand that the liners are made from a better quality ( less porous, harder wearing ) cast iron than the original 50 year old cast block :?:
251 ENG
Post by 251 ENG »
Most cooper S blocks used in competition 1293 engines will probably have liners in now because STD bore blocks are so hard to find . I know that swiftune use lots of linered blocks in there race engines .
The spun cast iron used in liners does seam to be of superior quality to the original iron used in the blocks .
Many people believe this helps the engines to rev better .
kit of bits
Been thanked: 14 times
Post by kit of bits »
Hello
So just to confirm, what's this worth.
It's 970??
Pete
Post by Pete »
kit of bits wrote:Hello
It's 970??
Looks like an early 1071!
smithyrc30
Post by smithyrc30 »
It's 970??
Looks like a 1071 FJ block to me....
251 ENG
Post by 251 ENG »
I have seen several FJ type blocks with original 970 tags still riveted on the back .
As far as I can make out they replaced the FJ type in early 64 so could easily have used them for early 970,,s
kit of bits
I'll post some more pics later
It has a 970 tag..
dutchacme
Post by dutchacme »
@kit of bits:
does the block come with the original caps?
kit of bits
Here's a few more pics
