Anyone come across one of these before? It is quire a well made thing but no obvious maker marks.
The part that mounts to the carb can be rotated to get the snorkel to lie where you want. The snorkel itself has seen better days though.
Think it would look good on Rich's TC
70s Air Filter Extension
Re: 70s Air Filter Extension
As above KN made 'em there called the 'KN Torque RAM' iirc
Probably good on a road car as it gives better torque and power below 4,000rpm (and less induction noise), but looses out once over 4,500 to a K&N with stub stack. See page 60 in the 1989 edition of Vizzard.
- Ronnie
- Been thanked: 7 times
Probably quite good for going through deep water, if you can turn the pipe enough!
Ronnie wrote:Probably quite good for going through deep water, if you can turn the pipe enough!
He he yes but it still leaves the distributor
I ran one of those on my first 998 back in about 1982 / 3
It made absolutely no discernible difference.
