Brake and fuel pipes
Hi i am just running the brake and fuel lines on my hydro car could any one advise on the route in the engine/front bulkhead, many thanks.
David
David
Re: Brake and fuel pipes
David , This any good ?? its of my 68 cooper
Thanks Ian
Thanks Ian
Here's mine.
- JanWulf
What's that little black bracket on the middle of the firewall for? Never seen (or noticed) it before... (second pic, to the very right)
Regards,
Jan
Regards,
Jan
You can't have too many cars. Just too little space...
- COOPERCO
Jan, it's for the speedo cable. The clip goes in a hole & then a grommet goes in to stop it coming back out. Stops the cable being fried on the exhaust manifold.JanWulf wrote:What's that little black bracket on the middle of the firewall for? Never seen (or noticed) it before... (second pic, to the very right)
Regards,
Jan
Mike.
In the garage with tourettes!
- JanWulf
Thank you!
Is it still available? I'm having problems with the speedo cable touching the manifold...
And cable ties are not realy that neat a solution.
Regards,
Jan
Regards,
Jan
- COOPERCO
Opps! Didn't type quick enough
Not sure if the clip on the front subframe for the brake pipe would open up enough for the cable? May be worth a look....
Mike.
Mike.
this should be the clip,
http://www.somerfordmini.co.uk/eshop/in ... ts_id=4575
Is the Somerfords one a later style one as Al's looks to have a circular mount to it or is that just the way the hole looks on the image? Whatever I need one too.
- COOPERCO
Not the best image on the Somerford site but looks similar to me. The flat section goes in the hole in the bulkhead & the round section grips the cable. The rubber grommet stops the clip being pulled back out of the hole.
