Float bowl lids & floats
JanWulf
Post by JanWulf »
Hi!
Untill when have the 'flat' float bowl lids been used on Minis? I recently aquired a box full of old carbs. Amongst them were two with the 'flat' lids. I wonder how long they have been fitted?
And has anyone got any good ideas of how to seal a (plastic) float? I'd usually just use another, but I want to use the early type with the adjustable metal strap. Of which I only got two. And they'r going into a twin-carb setup. It's not split open yet, but it's started to crack and I want to be one the safe side of things.
Thanks! :)
Regards,
Jan
PS: If anybody has a spare lid for sale like the dirty one on the picture. Let me know ;)
Perhaps attached to a healthy metal-strap-type float? ;)
You can't have too many cars. Just too little space...
Re: Float bowl lids & floats
The earlier tops were the ones without the ridge around the edge, they seem to have finished in the mid 60's.
As far as fixing a plastic float is concerned, if you HAVE to do it I would suggest taking the leaky float drilling 2 holes in it one about 8mm dia the other about 3mm & injecting the float with the type of "Squirty Polyeurathane foam" that is sold by builders merchants. Squirt it in ensuring it completely fills the float & let it dry thoroughly before giving it a try. The Polyeurathane is fuel proof so this fix should last a good long time.
JanWulf
Post by JanWulf »
Thanks Mark!
Good thought, filling it with foam. But going by your words I think it's probably better to search for a new float realy... Hmm...
Regards,
Jan
Probably better to find a good one really, but I am sure the above would work OK.
Ronnie
Has thanked: 6 times
Been thanked: 19 times
Post by Ronnie »
Dont forget if you use the foam, you will (to use a mainly nautical term) alter the displacement (it's carrying more cargo) :)
Toby
Has thanked: 7 times
Post by Toby »
When I was rebuilding the carbs of my mini I noticed that there were quite some differences to the lids.
Here is a picture of two that came with my set :
Notice the length of the pipe on the one without the rim to it, alongside with that it has the extra bulge on the lid.
T.
JanWulf
Post by JanWulf »
Yes, interessting, isn't it? :) You don't want to know how long it took me to find a carb that was the same as my RH carb... I've given up to count all the differences... :lol:
@Ronnie: Yes. After a bit more thought - I'm looking for a 'new' float. Thanks forthe input! :)
Regards,
Jan
