WTH??!?! Have you seen this item on ebay.
gs.davies
Has thanked: 12 times
Been thanked: 29 times
Re: WTH??!?! Have you seen this item on ebay.
Post by gs.davies »
Spitz wrote:
Simon776 wrote:
Not sure about this shell, is it an automatic there is no hole for the gear lever:
http://www.ebay.co.uk/itm/Mini-MK3-shel ... 1832983300
I'm not seeing much Mk 3 about that shell, square tunnel, later front subframe mounts, single cable handbrake etc.
Well it does hae a drip edge....and a rod change MkIII would have a square tunnel wouldn't it? Maybe a "crossover" year 75/6?
Seems to have an S front panel
"No welding required"
Not yet anyway. With those oversills you can guarantee that it soon will..
rich@minispares.com
Post by rich@minispares.com »
it looks like the entire floor and most of the transmission tunnel (missing gear hole...) are made for plates and patches as well.
verdict...
DOG!
'long beard boss'
Nick W
Post by Nick W »
saw some nos ones like those go for only £80 a few weeks back
I bet if I put mine on that's whats Ill get :!:
Up North in Sheffield
steve1071
Post by steve1071 »
Leave it a few weeks Nick and the madness will no doubt continue.
smithyrc30
Post by smithyrc30 »
For those ADO 16 types here is a genuine 1100 twin carb exhaust manifold.
http://www.ebay.ie/itm/BMC-NOS-Exhaust- ... SwzhVWtgMa
Proper BMC not a rubbish Chinese copy.
Jamie
Post by Jamie »
Maguire rolling shell......perfect for Blyton?
http://www.ebay.co.uk/itm/Mini-maguire- ... SwpzdWth4B
Spitz
Post by Spitz »
smithyrc30 wrote:For those ADO 16 types here is a genuine 1100 twin carb exhaust manifold.
oooh...I have one of those on a "parts car" with a 998. Also have the proper elbow. I think these can only be used with an electric fuel pumped car.
Pete
Been thanked: 33 times
Post by Pete »
This early Mark 3 would probably have been in really good nick before it was dumped outside....
http://www.ebay.co.uk/itm/Austin-Mini-f ... 2279059673
rich@minispares.com
Pete wrote:This early Mark 3 would probably have been in really good nick before it was dumped outside....
whats the betting its rung within the next six months....
'long beard boss'
smithyrc30
It's an auto as well, can't have been that many of those about when new let alone now.
It is a very early one as well, look at the bonnet hinges. That sort was only in for the first few months of mk3 before they reverted back to the original design.
Shame it has been let go that far.
smithyrc30
Quite a nice early mk1 here, looks to have most of its original trim but less some of its body work. :D
LDR209H
Post by LDR209H »
:D :D :D :D :D
Has thanked: 61 times
Been thanked: 54 times
smithyrc30
Saw these on the bay:
Another early mk3, a 1969 this time:
http://www.ebay.co.uk/itm/Classic-1969- ... SwuAVWt0Yn
The mk1 alluded to earlier, with only part of its body but with very good seats:
http://www.ebay.co.uk/itm/Morris-Mini-M ... 1799957264
Clubman with most of the work done, apparently:
http://www.ebay.co.uk/itm/1977-MINI-CLU ... SwJb9Wtlr5
With the state of the floor and welding on this van, the seller was a very brave person when getting the pictures. Apparently it was fitted with a 4 killer wasp heater and went to Norway:
http://www.ebay.co.uk/itm/Morris-Mini-V ... SwUV9WnQlM
This will not have done much. Mostly driven between cafes.....
http://www.ebay.co.uk/itm/SHOW-WINNING- ... 2279316519
An A40 for those wanting an alternate 2 door sports saloon:
http://www.ebay.co.uk/itm/Austin-A40-Fa ... 2279316519
For those with an epic sense of humour:
http://www.ebay.co.uk/itm/2-austin-maxi ... 2279316519
As an ex-BT wire cutter I know the abuse those yellow vans suffered. A particular favourite was to switch off the ignition for a couple of seconds whilst going down hill, then scaring passers by with the almighty back fire when it was switched back on. Please do not try this at home!
STG95F
Post by STG95F »
Spitz
Post by Spitz »
That Clubman is cool.
I thought only the S had hydro in 70….learn something new all the time
rich@minispares.com
Spitz wrote:That Clubman is cool.
all early clubmans had it, I guess they where using stocks up, or where trying to promote the 'new' clubman as been a better, smoother car to ride in than the normal mk3 mini
'long beard boss'
Matt_Tupman
Post by Matt_Tupman »
STG95F wrote:Early Clubman , back up for sale :o
http://www.ebay.co.uk/itm/1970-MORRIS-M ... SwWTRWu4ie
Optimistic pricing!
Pickups imported to UK from South Africa:-
http://www.ebay.co.uk/itm/CLASSIC-MINI- ... SwKtlWnhoL
