Posts: 6235 Joined: Thu Jun 24, 2010 3:26 pm
Been thanked: 6 times
Post
by UHR850 » Sat Jan 02, 2016 3:27 pm
Does an Astrali Mk1 tulp boss fit on the 33EJB Les Leston wooden steeringwheel ?
Kees
almondgreen
Posts: 1036 Joined: Thu Jun 24, 2010 12:32 pm
Been thanked: 1 time
Post
by almondgreen » Sat Jan 02, 2016 3:57 pm
I think so
Post
by UHR850 » Sat Jan 02, 2016 7:35 pm
Thanks, I'll hope so too
Kees
Post
by UHR850 » Sun Jan 03, 2016 3:57 pm
It will fit !!
Tedwong
Posts: 468 Joined: Thu Jun 24, 2010 4:48 pm
Been thanked: 2 times
Post
by Tedwong » Mon Jan 04, 2016 9:51 am
The Astrali boss may not fit I'm afraid, as this question has been discussed.
viewtopic.php?f=3&t=12928
Andreas please confirm.
abri
Posts: 746 Joined: Tue Jun 29, 2010 4:25 pm
Post
by abri » Mon Jan 04, 2016 6:00 pm
That's odd. The distance between the two holes at 3 and 9 o clock on my wheel was exactly the same as on my boss (Astrali). I measured it before buying my wheel because I wouldn't fork out another fortune on all the LL boss bits. I think there may have been one of the holes on the boss that needed a tiny bit of adjustment with a needle file.
Post
by UHR850 » Mon Jan 04, 2016 6:46 pm
Posts: 19846 Joined: Thu Jun 24, 2010 11:30 am
Has thanked: 3 times
Been thanked: 8 times
Post
by mk1 » Tue Jan 05, 2016 9:17 am
Re drilling the boss would be easy.
As the holes are close to the inner edge, it would probably make most sense to drill & tap suitable holes in the boss, rather than use nuts.
Post
by UHR850 » Tue Jan 05, 2016 10:36 am
Yes maybe I will do this, thanks for the tip !
But I think it will not work like this because
you have to turn the boss a bit.
If you do that the hole for the screw will be
on the wrong place and you can fit the Mk1
horn push not in the right way anr more
Kees
Post
by UHR850 » Tue Jan 05, 2016 1:58 pm
Well it fit lits a glove, no drilling just restore the wheel and fitting it on the Astrali A1 boss
Kees
Post
by mk1 » Tue Jan 05, 2016 2:05 pm
Looks OK to me
The way to get round the problem you identify above is to drill & tap the holes as necessary then fit the horn push, mark where the slot in the side of the badge needs to be & file a new one out. This is however totally redundant as your boss obviously fits perfectly.
almondgreen
Post
by almondgreen » Tue Jan 05, 2016 2:58 pm
glad that I was right
Nick W
Posts: 2892 Joined: Sat Jan 17, 2015 8:59 pm
Has thanked: 1 time
Post
by Nick W » Tue Jan 05, 2016 6:52 pm
Thats my favourite wheel too, I have one but it needs some holes welding up , I might give it the machined swerled look to hide the welds
Nick
Up North in Sheffield
Post
by UHR850 » Wed Jan 06, 2016 8:53 am
It was on top of my wish list, now I only have to buy a Mk1 for it
Kees
Post
by UHR850 » Sat Jan 09, 2016 2:41 pm
abri
Post
by abri » Sat Jan 09, 2016 4:56 pm
Gorgeous, gorgeous, gorgeous!!
Post
by UHR850 » Sat Jan 09, 2016 7:26 pm
ianh1968
Posts: 1012 Joined: Sat Nov 03, 2012 6:00 pm
Post
by ianh1968 » Sun Jan 10, 2016 6:10 pm
Nick W wrote: I might give it the machined swerled look to hide the welds
My Dad used a pillar drill and a piece of dowel dipped in fine valve grinding paste...
What's your "method"?
Nick W
Has thanked: 1 time
Post
by Nick W » Sun Jan 10, 2016 7:41 pm
The one I have was in a sorry state with cracks through 2 of the original mounting holes and 6 extra holes , probably to fit it to a tulip boss , it's the small hole version ,not sure what boss it requires for the mini?
I welded the extra holes ,it welded fine so After Id welded the two cracked original hole's I thought I may as weld the lot and start again.
I've done the machine swirls before with a bench drill and scotch pad Rolox discs
The trick is not to be random but mark out where they are to be done
But after sanding and polishing There's nothing to hide so may just leave it polished
Nick
Post
by UHR850 » Mon Jan 11, 2016 6:15 pm
Very nice job, well done !
But I realy would like to have the original LL boss !
Kees
