I have a 100mph dead speedo which has the 5 digit plus 10ths of a mile trip, only 3 lights. high beam (blue), indicator (green) and ignition (red)
I also noticed has the 90 and 100mph inverted??
At what time point did this type of speedo get introduced?
Was the early 997 Cooper fitted without the trip?
997 speedo change
- mini63
Re: 997 speedo change
Sounds about right. Inverted numbers, tenths trip, 3 jewels.
Is it 4479/06 ? If so, it was used from May 62 to Sept 64. It was the second type used on the 997 .
Wasn't the "green" the oil pressure lamp?
... with the indicator being on the end of the stalk...
- Has thanked: 125 times
- Been thanked: 34 times
No lamp for Oil, they had a gauge.ianh1968 wrote:Wasn't the "green" the oil pressure lamp?
- minimans
Blocked filter light?Spider wrote:No lamp for Oil, they had a gauge.ianh1968 wrote:Wasn't the "green" the oil pressure lamp?
I'm pretty sure they came in after the 997 Cooper, though, I'm no expert on the model. I seem to recall in my mates 997 the green one in the speedo wasn't used.minimans wrote:Blocked filter light?Spider wrote:No lamp for Oil, they had a gauge.ianh1968 wrote:Wasn't the "green" the oil pressure lamp?
No gauge in a 1964 Morris Minor 1098 that I work on, only a lamp!Spider wrote:No lamp for Oil, they had a gauge.ianh1968 wrote:Wasn't the "green" the oil pressure lamp?
I was guessing that the 997 Cooper speedo would be the same...
(or at least very similar).
