Attached a photo of the clutch arm.
Do you think the wear / possible bend would be enough to cause the issue?
Coil Spring Clutch nightmare
- Rich997
Re: Coil Spring Clutch nightmare
- Andrew1967
It's definitely worn and will cause some clearance issues. Not sure about the angle. If it was mine I would weld and reprofile the ball.
If the hole in the plunger is also ridged, it will exacerbate the problem further.
- pad4
- mini63
No....Rich997 wrote:Attached a photo of the clutch arm.
and from memory I recall occassionally putting a thin section shim washer under the 'press on' type release bearing to reset the clutch slave piston location.
