Cutting braided fuel hose
- tomkidd
is a flippin ball ache! Any tips?
I've wrapped it in electrical tape (tight) and used a hacksaw but it still frays enough to not let me get the hose ends on... grrrrrrr.
Re: Cutting braided fuel hose
i always wrap the hose with masking tape, then cut using an angle grinder fitted with one of the really thin steel cutting dics. the teflon hose will require a light deburr and a thorough flush through .
- tomkidd
Cheers, its an6 ptfe. I will try a cutting disc tomorrow
sawing is a total loss, i use a feck off big chisel and lump hammer on the back of a knackerd vise. you get a good straight tidy cut every time, i find that also the flattend shape the hose goes actuly helps a tad with puting the threaded collor on,
you should try -12 somtime
Dremel is easier to control than a grinder.
Have heard both the (sharp) chisel and aviation snips techniques work well though.
- tomkidd
Cheers guys. I'll try the dremel cutting disc tomorrow
air powered cutting disc here I always wrap the section i'm cutting in masking tape first.
Caution may contain 8 Ports, Xe's and VTec's, I don't do standard!
well i can cut it with a saw! so i guess im not a flid! haha, cutting discs work better though but dont get it too hot
I never knew there were so many methods of doing the same thing
Am a wrap it in tape & hit it with the angle grinder type guy myself.
- tomkidd
Which end of the grinder Mark?mk1 wrote:I never knew there were so many methods of doing the same thing
When using the tape , make sure you wrap it TIGHT . Also , what type of tape you use can make a difference . Black electrical tape will expand slightly allowing the steel braid to "Flare" out . We use a Glassfibre tape at work which doesn't expand at all after the cut has been made.
Craig
Craig
