dunlop r7 rolling radius
sclemow
Post by sclemow »
Hi All
Does anyone know where I can find the rolling radius data for dunlop r7 tyres for calculating speedo gears?
The engine is out, so measuring it is a bit tricky as it will be unloaded .....
S
ivor badger 2
Re: dunlop r7 rolling radius
Post by ivor badger 2 »
It used to be in the Dunlop catalogue, so try the online racing tyre site. the casing is so stiff, that measuring it with the engine out makes little difference
From Special Tuning 1275GT and Cooper S AKD 5096
Dunlop Tyre and Size R7 500 L10
Wheel revs per mile at 30mph 1053
But that's probably for the old tyres
from Vintage tyres
Type: RADIAL
Diameter: 488 mm
Section Width: 175 mm
Max Speed: 130 mph
Max Load: 355 kg
Weight: 5.5 kg
If the diameter is 488mm then I guess the tread circumference must be 1532mm (approx.) which works out as 1050 revs per mile. This does not allow for any tyre deflection.
sclemow
Post by sclemow »
Thanks guys. Surfblue is this the modern R7's?
I guess not if it's from the special tuning documentation?
I wonder if they are the same?
Simon
Just edited my first post with details of the modern radial type. The ones in the old ST book were cross-plies I think, judging by the tyre sizing.
sclemow
Post by sclemow »
Thanks surfblue, very much appreciated. I found that info and was looking to work out the revs per mile with deflection.
I'm still digging but haven't found it on the dunlop site yet.
Simon
ianh1968
Post by ianh1968 »
sclemow wrote:I found that info and was looking to work out the revs per mile with deflection.
My copy of the ST manual also shows the 500 L10 R7 at 1053WRPM.
At the top of the column it states that this is "at 30 MPH".
This must therefore be under load or "with deflection", then?
Vegard
Post by Vegard »
Dunlop, please make me some CR84s please!!!!!!
ivor badger 2
Vegard wrote:Dunlop, please make me some CR84s please!!!!!!
Why, when CR81s were better and the slick even more so.
