I've almost finished the short engine and I would like to fit a fixed pointer so that I can mark the key points onto the damper - TDC, 15 degrees, 33 degrees etc.
Dez Hammill describes doing this in his book where he advises brazing on a 'blade' to the front cover but that is on an A+ which has a different timing case and a larger area where the 'blade' can be located.
I need to put the pointer in a position which will be seen when the engine is fitted but I have no reference point to gauge this as the engine is not in the car.
Can anyone advise what they have done in this regard? I was thinking of rigging something up which could be fixed using the timing case bolts but I would prefer something which is properly 'fixed' a la Dez's suggestion.
Any suggestions would be appreciated - photos even more so
Jon
