Thanks for the replies...
1) I have decided to fit the spindles round the right way.
I reckon that as grease is "fluid", it will find the easiest path to escape from.
The bearing is fairly open, and the bush isn't. My guess is that the grease will
not force its way through to the outside when it could more easily escape from
the closest/bearing end. (If fitted reversed).
When fitted the correct way, the first end, ie, the bush, is more restrictive,
but there is also the extra resistance in forcing the grease down the tube which
will ensure that some will come through the bush.
2) I will have a good look at the old rubbers and will probably use them if they
are OK.
3) The brake bias valve will be fitted in the normal orientation, but
Question 4...
I want to use Goodridge-type hoses and have only a single pipe with no joins
going from each side of the valve direct to the cylinder, with a banjo being on
the cylinder end.
With my Mini, it was a later car and did not have the valve - It was easy to get
swivelling straight female connectors to do the job with a plain male/male/male
stainless tee.
The Marcos has the valve and accordingly, I need to connect a standard tube-nut
type fitting at the valve end... I don't want a banjo at both ends as I'll probably
end up with the ends on with the wrong orientation and the pipes will be twisted.
So - What I am trying to find is a pair of Dash-3 straight connectors, in stainless
steel... They must swivel, as the other end will be anchored by the banjos.
The closest thing is this 445-45, but it's metric and at 45 degrees - I want a
straight 3/8"UNF version of the same thing.
http://www.giefferacing.com/eng/models/ ... ngs_1.html
I am not overly fussed if the pipes are Goodridge or not, as long as I can get
the pipes I want. An option would be to put a male/male adapter in each exit
hole on the valve and then use exactly what I used before...
Any suggestions would be greatly appreciated...
TOP TIP:
If making a box-beam to hinge your trailing arms from, use 80x40mm section...
My previous effort was based on a MiniSpares offering which I bought and
shamelessly got some ideas from. Their tube was 2"x3", or 50x75mm.
When I put my MKI version together on the Mini, the wheels were set further
back in the arches and it was and still is, visibly wrong.
I have just dropped the Marcos on the floor again with a 80x40mm beam and
am pleased to advise that the wheels are still in the "correct" position...
This MkII version uses the brackets from the MS kit, so any variation is purely
down to the difference in box section thickness.
I noticed recently on the MS website that there was a reference to this wrong
alignment "feature" and I am wondering why they don't just do what I did and
use a more suitable section?
