Maniflow LCB Exhaust Manifolds
ianh1968
Post by ianh1968 »
I'm looking to get a new manifold...
C-AEG365 vs. C-AEG376
"Normal" vs. "Stage II with a larger centre pipe"
Has anybody used this version and can make a comment about
"Standard LCB" vs. "Stage II"?
MiniSpares Website wrote:thus producing an improved BHP,Torque and power curve.
Has anybody seen any figures to back up this statement for the "376" version?
On a previous engine spec 1380cc, 286 Scatter, 1.5, 1.463"/1.218", 11:1, HS6, Howley, K&N, etc
the LARGE bore that I had run for several years gave significantly LESS bottom end than
the medium that replaced it.
The engine has grown to 1480cc, with a 276 cam replacing the 286 Scatter...
... I don't want to take a step backwards with bottom end torque!
Cables
Re: Maniflow LCB Exhaust Manifolds
Post by Cables »
I would speak to maniflow themselves and see what he recommends for your setup/requirements, i've got the stage 3 lcb on my track, its a very tight fit but you can tell the difference, and it hasnt negatively affected low down power
ianh1968
Post by ianh1968 »
Thanks! Just phoned Maniflow...
On the specification as above, the immediate response was that the Stage II would
be the way to go. From the conversation I was having, it also became quite clear that
a road car with about 100Bhp SHOULD NOT be running a large-bore LCB...
YMJ
Post by YMJ »
ianh1968 wrote:Thanks! Just phoned Maniflow...
Correct. I built a road car with a 1000c Mini 7 motor and it was undriveable with the race LCB. Replaced it with a pretty crap £19.99 pattern LCB and it was transformed...no flat spots, easily pulled away from the lights under 2500rpm without me (or the wife) looking like a total prat.
