i like to have you advice on the dyno result of my engine, the power curve go flat from 6750 to 8000 rpm and i am thinking about the point going bouncing,
my engine specification is
gt block bored out to 1293
forged omega 5.8cc pistons
36/31 race head
1.5 forged rocker
12/1 cr
sw23 cam
twin h4 with bg needle and blue spring
stg 3 race maniflow lcb with race reverse cone system
full straight cut box
ultralight fly
wedged crank
aldon red distributor with point timed at 28° full advance
would fitting of electronic module in the distributor change someting or this is a normal curve for these profil of cam, have asked swiftune but no reply at the moment
here the dyno graph, make 109 hp and 122nm, AFR is good from 5000 to 8000 at 12.5
thank for you advice
