I thought it may be interesting to some people if I did a step by step guide to the refurbishment & improval of this head.
After initial stripping it was found that the rocker pillar threads were all more or less knackered to one extent or another. With badly inserted helicoils sticking out at all angles.
Somoene had "had a go" at number 1 pedestal. It had had a helicoil "fitted" but this was obviously still loose as the coil had been peened round to try 7 firm things up a bit.
Number 2 had been fitted correctly, but the coil had been overtightened for a second time cracking the pedastal foot.
Number 3 is the same but worse as the pedestal foot has broken off completely.
None of this damage is impossible to fix, & most can be done to a very successful extent by a competent home mechanic without too many specialist tools or equipment. I will set about this restoration in the near future & will show how this sort of damage can be sorted out.
