Hi Jens. Far too many distractions and a severe lack of Mojo are amongst my pitiful excuses for not getting on with the re-build.
I pulled the pedal box out and modified it by adding a later disc brake pedal for the "better feel" and while I was there I added a bracket for the brake switch..
There was a huge difference in the heights of the old and new pedals, but something else I noticed was the angle of the actual pad compared to the older (drum) pedal.
Made a start on the wiring. The donor loom came out of a late Clubby estate, but still needs modifying to accommodate some of my intended ideas. I'm trying to keep the engine bay reasonably clutter free, so the main loom is behind the dash, out of view.
In my effort to be different I've complicated matters by trying to replicate a "Motortune" dashboard. I'm crap at fibreglass so it will have to be made from another material.
I've made an alloy mock up and have basically lost interest, again.
In my collection of steering wheels is a nice 13" early flat Motolita, but I can't use it because I'm unable to have a clear view of the instruments in my "new" dash.
So I have had to revert to using a 15" wheel to be able to see said instruments easily.
I really should pull my finger out. May 4th is not far away.
